UGS的也放这里好了
NX-to-VERICUT Interface (NXV)
Turning tools are now oriented correctly when passed to VERICUT through NXV.
A "Browse" button is added to the Output Directory feature on the NXV main window to
simplify specifying the directory to receive NXV files. This feature is implemented for
Windows only. It is not possible to implement for UNIX.
NXV now exports tools from NX correctly for situations where "Operation Navigator -
Program Order" includes one or more sub-directories with the tool definitions.
NXV is enhanced to support multiple VERICUT G-Code tables. A new group of features
"VERICUT GCode Table" on the NXV Options window enable you to specify:
Table Name – Select Work Offset, Base Work Offset, Program Zero, or None from
the pull-down Table List or enter a name in the Table Name text field.
Register Number – Enter the register number.
'From' Component — Select the name of the component that represents the "from"
point for determining the offset. VERICUT will use the origin of the specified
component. Select from the pull-down 'From' List or enter the name in the 'From'
Component text field.
'To' Csys — Select the name of a CSYS to represent the "to" point for determining
the offset. VERICUT will use the origin of the specified CSYS. Select from the pulldown
'To' List or enter the name in the 'To' Csys text field.
Tool features are now correctly passed to VERICUT through NXV when using NX4.
NXV is enhanced to enable transferring NX turning data (turning tools, stock from a 2D
profile, design from a 2D profile, CLS NC program) to VERICUT.
A new checkbox "Transfer All Coordinate Systems" is added to the NXV Options
window enabling all NX coordinate systems associated with current NC program to be
passed to VERICUT. When toggled "off", only the coordinate systems required by
VERICUT (PROGRAM_ZERO and ***STOCK***) will be transferred.
Environment variable CGTECH_NXV_OUTPUTDIR is added to enable specifying a
default output file. Example of use:
set CGTECH_NXV_OUTPUTDIR=C:\Documents and Settings\Username.
NXV determines the default output directory according to the following rules:
1. If the environment variable is set, its value is used as the default output directory.
2. If the environment variable is not set, the value saved in the NX model is used.
3. Finally, if neither of the above is used, the directory containing the NX model is
used.
NXV is enhanced to enable passing multiple NX fixture models to VERICUT as
individual STL models.
A new feature "Attach Component List" is added to the NXV Options window to
simplify the specification of the Attach Component Name. Attach Component List
enables you to select the desired Attach Component from a pull-down list. The pull-down
list contains all of the Attach Components contained in the machine referenced by the
specified Setup Template.
NXV is enhanced to more accurately pass the following types of NX tool features into
VERICUT.
• When the NX Tool Insertion - (OS) Offset feature is used to specify how far the
Holder overlaps the Cutter.
• NX User Defined tools.
• Counter sinks created in NX under their "hole making" category.
NXV is enhanced to support the NX center drill definition.
NXV now correctly passes NX defined step drills into VERICUT.
NXV now correctly passes NX4 APT 7 parameter drilling tools to VERICUT. |
