查看: 15769|回复: 1
[求助] 求助
发表于 2009-5-14 11:53:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如何等参数离散曲线?
很急 希望各位帮帮忙~~!
UF_MODL_evaluate_curve (
tag_t curve_id,
double * param,
int * deriv_flag,
double * pos_and_deriv );
这个具体要怎样用?
发表于 2009-5-14 12:34:29 | 只看该作者
extern int UF_MODL_evaluate_curve (
tag_t curve_id,
double * param,
int * deriv_flag,
tag_t  curve_id Input Object identifier for the curve
double *  param Input Parameter at which to evaluate
int *  deriv_flag Input Number of derivatives to evaluate.
UF_MODL_LOC = Return the point
UF_MODL_LOC_1STDERV = Return the
point and 1st derivative
UF_MODL_LOC_1STDERV_2NDDERV =
Return the point, 1st and 2nd derivative
double *  pos_and_deriv Output Position and derivative.
Dimension of the array = 3 * (deriv_flag +1)
GMT+8, 2025-4-6 17:15 , Processed in 0.022257 second(s), 13 queries , Gzip On, Redis On.
