查看: 17063|回复: 1
[求助] 请教整车仿真为什么出错?
发表于 2009-5-16 10:25:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
做整车仿真出现下列问题,请高手指点。说明一下:我的后悬架是钢板弹簧非独立悬架,用三段梁理论建的,其它都是用ADAMS自带的模板。做蛇形和单移线仿真都没有问题。但下面两个仿真出错:
1、角脉冲转向仿真
--- WARNING ----
   Out-of-range Z value for SPLINE c_imp._cv_spline is used for calculation.
   The Z value ( 0.0 ) should be between 1.0 and 2.0.
---- ERROR ----
   The system matrix has a zero pivot for column 769, which is associated
   with VARIABLE/64 Algb Var.  Consequently, the matrix is numerically singular.
2、阶跃转向仿真
---- WARNING ----
   Out-of-range Z value for SPLINE o_step._cv_spline is used for calculation.
---- WARNING ----
   An out-of-range X value has been used in the spline calculation.
   Extrapolation is required for the SPLINE o_step.TR_Steering.gss_steering_assist.
   The X value ( 3.2610 ) should be between -3.0 and 3.0.
---- ERROR ----
发表于 2009-11-25 14:51:48 | 只看该作者
等待高手。我也遇到了问题
GMT+8, 2025-4-26 23:42 , Processed in 0.019470 second(s), 11 queries , Gzip On, Redis On.
