查看: 16720|回复: 17
PTC用戶要留心
发表于 2003-6-10 21:51:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Title Pro/ENGINEER Part Files Created or In Certain Cases Saved With Release 2001, Datecodes 2003120 and 2003160 or Release Wildfire, Datecode 2003130 Cannot Be Properly Retrieved And Regenerated In Earlier Datecodes.
Product Pro/ENGINEER Module RETRIEVAL TAN ID 121172 Created 20-MAY-03
Workstation All Reported In Release 2001 Reported In Datecode 2003120
SPR 1016697 Resolved In Release Resolved In Datecode
PTC has discovered that there is an issue in the following datecodes of Pro/ENGINEER such that models saved in these builds cannot be successfully regenerated in earlier builds of these releases. For example, a model saved in Pro/ENGINEER 2001 2003120 When retrieved in earlier Pro/E builds, but when regenerated, section-based features will fail, and failure investigation will result in a premature exit. The affected builds are:
Pro/ENGINEER 2001, datecode 2003120 and datecode 2003160
Pro/ENGINEER Wildfire datecode 2003130
PTC has stopped shipment and download availability of these builds, and is recommending that customers do not deploy them, and consider the following points if they have already been deployed.
A fix for this issue will be available in the following builds of software:
Pro/ENGINEER 2001, datecode 2003161, which will be available for download from PTC's Software Updates page on May 29, 2003, and will begin shipping to customers on June 6, 2003
Pro/ENGINEER Wildfire datecode 2003170, which will be available for download from PTC's Software Updates page on May 30, 2003, and will begin shipping to customers on June 9, 2003
If you are currently running Pro/E 2001, datecode 2003090 or earlier, PTC recommends that you not upgrade to Pro/ENGINEER 2001, datecode 2003120 or datecode 2003160. Please note that Pro/INTRALINK 3.3 has now been certified with Pro/ENGINEER Release 2001, datecode 2003090.
If you have already deployed Pro/E 2001, datecode 2003120 or datecode 2003160, PTC recommends that you avoid working with any of this data in earlier builds of Pro/ENGINEER 2001, as any models saved in this build will be incompatible with earlier builds of Pro/E Release 2001. However, once you have upgraded to Pro/ENGINEER 2001, datecode 2003161, and retrieved and saved the models, they will be compatible with Pro/E Release 2001, datecodes 2003090 or earlier. If you choose to retrieve models created in either datecode 2003120 or 2003160 in datecode 2003090 or earlier, you will likely experience regeneration failures and premature exits. If you save models (which were saved in datecode 2003120 or datecode 2003160) in datecode 2003090 or earlier, this may cause irreversible damage to your model files.
If you are currently running Pro/E Wildfire, datecode 2003100 or earlier, PTC recommends that you not upgrade to Pro/E Wildfire, datecode 2003130. Instead, once it is available, you should upgrade to Pro/E Wildfire, datecode 2003170, which will be certified with Pro/INTRALINK 3.3.
If you have already deployed Pro/E Wildfire, datecode 2003130, PTC recommends that you avoid working with any data created in this release, in earlier builds. However, once you have upgraded to Pro/ENGINEER Wildfire, datecode 2003170, and retrieved and saved the models, they will be compatible with Pro/E Wildfire, datecodes 2003100 or earlier. If you choose to retrieve models saved in datecode 2003130 in datecode 2003100 or earlier, you will likely experience regeneration failures and premature exits. If you save models (which were created in datecode 2003130) in datecode 2003100 or earlier, this may cause irreversible damage to your model files.
发表于 2003-6-10 21:52:28 | 只看该作者
意思是2003130不要用,因為用這一版本作的圖,在以後的版本是不能再用甚至不能打開或再存檔,小則程式會跳出或關閉,大則會損壞圖檔。
发表于 2003-6-10 23:24:33 | 只看该作者
不要恐吓我,我刚想装进去,我现在的2002490是 英文的 ,这2003130
可是中文的啊,请高手出来澄清
头像被屏蔽
发表于 2003-6-11 08:01:22 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2003-6-11 08:03:28 | 只看该作者
andywang307 wrote:
俺是2003100
2003170
发表于 2003-6-11 08:42:25 | 只看该作者
版本也太多了,请问最最最新的是哪个?
发表于 2003-6-11 09:33:59 | 只看该作者
最新的是哪个 2003170
发表于 2003-6-11 09:34:19 | 只看该作者
2003170
发表于 2003-6-11 09:42:55 | 只看该作者
靠,不会吧!我用的还是2003051呢?是真的还是假的啊,我得去问问PTC的朋友!!!
发表于 2003-6-11 09:45:01 | 只看该作者
我是2001
GMT+8, 2025-4-27 18:22 , Processed in 0.029442 second(s), 11 queries , Gzip On, Redis On.
