查看: 15946|回复: 7
[求助] 生成四方块的代码错在哪里?先谢谢啦!
发表于 2009-5-29 19:44:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下面是生成生成四方块的代码,在编译时出错,请高手帮忙看看是什么原因……
//  41.cpp
//  Description:
//      Contains Unigraphics entry points for the application.
//  Include files
#include <uf.h>
#include <uf_exit.h>
#include <uf_ui.h>
#if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )
# include <strstream>
#   include <iostream>
using std:strstream;
using std::endl;
using std::ends;
using std::cerr;
#else
# include <strstream.h>
#   include <iostream.h>
#endif
#include "41.h"
//  Activation Methods
//  Unigraphics Startup
//      This entry point activates the application at Unigraphics startup
extern "C" DllExport void ufsta( char *param, int *returnCode, int rlen )
    /* Initialize the API environment */
    int errorCode = UF_initialize();
    if ( 0 == errorCode )
        /* TODO: Add your application code here */
   double corner_pt[3]={10,10,10};
         char *edge_len[3]={"30","20","10"};
         tag_t blk_tag;
         UF_MODL_create_block1(UF_NULLSIGN,corner_pt,edge_len,&blk_tag);
        /* Terminate the API environment */
        errorCode = UF_terminate();
    /* Print out any error messages */
    PrintErrorMessage( errorCode );
//  Utilities
// Unload Handler
//     This function specifies when to unload your application from Unigraphics.
//     If your application registers a callback (from a MenuScript item or a
//     User Defined Object for example), this function MUST return
//     "UF_UNLOAD_UG_TERMINATE".
extern "C" int ufusr_ask_unload( void )
    return( UF_UNLOAD_UG_TERMINATE );
/* PrintErrorMessage
**     Prints error messages to standard error and the Unigraphics status
**     line. */
static void PrintErrorMessage( int errorCode )
    if ( 0 != errorCode )
        /* Retrieve the associated error message */
        char message[133];
        UF_get_fail_message( errorCode, message );
        /* Print out the message */
        UF_UI_set_status( message );
        // Construct a buffer to hold the text.
        ostrstream error_message;
        // Initialize the buffer with the required text.
        error_message << endl
                      << "Error:" << endl
                      << message
                      << endl << endl << ends;
     // Write the message to standard error
        cerr << error_message.str();
发表于 2009-5-29 19:50:52 | 只看该作者
我上面那段代码有什么问题啊!高手帮忙看看!!
为什么上面那段代码在编译时会报:41.obj - 1 error(s), 0 warning(s)  这个错呢???
发表于 2009-5-29 20:39:45 | 只看该作者
头文件加一下
发表于 2009-5-30 19:01:14 | 只看该作者
头文件未包含
发表于 2009-5-30 20:38:20 | 只看该作者
请问楼上两位仁兄,头文件不是VC自动生成的吗?楼上所说的“头文件未包含 ”是指什么?头文件怎么加啊!??请多多指教小弟……多谢啦!!!
发表于 2009-6-2 16:13:17 | 只看该作者
#include <uf.h
#include <uf_ui.h>
后加
#include<uf_modl.h>
发表于 2009-6-3 17:36:08 | 只看该作者
问题已经解决!!!多谢楼上三位兄弟的热心帮助。
发表于 2009-6-13 14:25:34 | 只看该作者
GMT+8, 2025-4-30 14:07 , Processed in 0.022907 second(s), 11 queries , Gzip On, Redis On.
