查看: 15526|回复: 1
[求助] 求交的函数
发表于 2009-6-1 19:05:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
tag_t object_1=NULL_TAG;
tag_t object_4=NULL_TAG;
char *name_1="ren";  //是一个体,命名为ren
char *name_4="ti";   //另外的体,命名为ti
UF_OBJ_cycle_by_name(name_1,&object_1);   //通过名字得到各自的对象
UF_OBJ_cycle_by_name(name_4,&object_4);
把上面两个函数的输出输入到下面的函数
status=UF_MODL_intersect_objects(object_1,object_4,tolerance,&num_intersections,&intersections);
if (status !)
    UF_get_fail_message(status, messg);
结果num_intersectins=0
错误提示信息是:无效的对象tag
请问错误到底出在哪?
发表于 2009-6-1 19:13:48 | 只看该作者
下面是两个函数的定义
int UF_MODL_intersect_objects
tag_t object_1
tag_t object_2
double tolerance
int * num_intersections
UF_MODL_intersect_info_p_t * * intersections
int UF_OBJ_cycle_by_name
char * name
tag_t * object
GMT+8, 2025-4-7 22:38 , Processed in 0.020248 second(s), 12 queries , Gzip On, Redis On.
