查看: 17431|回复: 7
[求助] UG二次开发中对话框创建问题
发表于 2009-6-15 12:52:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我先进行了对话框设计,存入目录,环境变量均已经设置,保存后生成了first_dlg.h ,first_dlg.dlg ,first_dlg_template.c三个文件,
然后用Visual C++生成动态链接库文件,用对话框的* temlate.c(改为*.cpp)和*.h文件替换\first_dlg目录下的*.cpp和*.h文件.
再对fisrt_dlg.cpp文件进行修改,
1)删掉"#ifdef MENUBAR_COMMENTED_OUT"和“#ifdef DISPLAY_FROM_USER_EXIT"分别对应的“#endef".
2)并将文件中的“<enter a valid user exit here>"改为"ufusr".
3)将文件中"#include <first_dlg.h>"改为"#include"first_dlg.h""
最后应该要编译连接生成first_dlg.dll,可是我的程序就是不能编译,总是提示:
first_dlg.cpp(459) : fatal error C1004: unexpected end of file found
可是我的程序只有到456行,下面的都是空的,
不知道哪里出了问题,还请高手帮助!谢谢!
发表于 2009-6-15 17:21:04 | 只看该作者
找到下面语句:
extern void <enter a valid user exit here> (char *param, int *retcode, int rlen)
#endif /* DISPLAY_FROM_USER_EXIT */
改为:
extern void ufusr(char *param, int *retcode, int rlen)
发表于 2009-6-17 16:50:38 | 只看该作者
我又把文件重新做了一次,但是,对*.cpp进行修改后,不能进行编译,出现错误提示为:
five_dlg.cpp(459) : fatal error C1004: unexpected end of file found
可是我的程序只有到456行,下面的都是空的,不知道怎么回事,还请高手帮忙!!谢谢
发表于 2009-6-18 13:17:55 | 只看该作者
还是把你的源程序放上来吧
发表于 2009-6-18 14:01:32 | 只看该作者
这是我的first_dlg.cpp的内容:
   WARNING!!  This file is overwritten by the UIStyler each time the Styler
   file is saved.
        Filename:  first_dlg_template.c
        This file was generated by the NX User Interface Styler
        Created by: Administrator
        Version: NX 4
              Date: 06-18- 9
              Time: 10:45
   This template file is overwritten each time the UIStyler dialog is
   saved.  Any modifications to this file will be lost.
   Purpose:  This TEMPLATE file contains C source and static structures to
   guide you in the construction of your NX Open application dialog.
   The generation of your dialog file (.dlg extension) is the first step towards
   dialog construction within Unigraphics.  You must now create a UGOpen
   application that utilizes this file (.dlg).
   The information in this file provides you with the following:
   1.  Help on the use of the functions, UF_MB_add_styler_actions and
       UF_STYLER_create_dialog in your NX Open application.  These functions
       will load and display your UIStyler dialog in Unigraphics.
       An example of the function, UF_MB_add_styler_actions to associate your
       dialog to the menubar is shown below (Search on Example 1).
       An example of a invoking a dialog from a callback utilizing
       UF_STYLER_create_dialog is also shown below (Search for Example 2).
       An example of a user exit utilizing UF_STYLER_create_dialog is also
       shown below (Search for Example 3).
   2.  The callback structure: --- MY_cbs ---
       This structure is VERY important if you have callbacks associated with
       your dialog.  It correlates the dialog items in your dialog with the
       callback functions you must supply.  You should not modify this
       structure since it MUST match up to the information stored in your
       dialog file (.dlg).  Any attempt to do so will cause an error while
       constructing your dialog.   If you wish to modify the association of
       your callbacks to your dialog, please reload your dialog file (.dlg) into
       the UIStyler and regenerate your files.
       You do not need to be concerned about this structure, simply pass it as
       an argument to the function, UF_STYLER_create_dialog along with your
       dialog file (.dlg).
       Example 1 displays the actual call you may make for this particular
       dialog.
   3.  The empty callback functions (stubs) associated with your dialog items
       have also been placed in this file.  These empty functions have been
       created simply to start you along with your coding requirements.
       The function name, argument list and possible return values have already
       been provided for you.
NOTE:  Each callback must be wrappered with the functions UF_initialize()
       and UF_terminate().
/* These include files are needed for the following template code.            */
#include <stdio.h>
#include <uf.h>
#include <uf_defs.h>
#include <uf_exit.h>
#include <uf_ui.h>
#include <uf_styler.h>
#include <uf_mb.h>
#include "first_dlg.h"
/* The following definition defines the number of callback entries */
/* in the callback structure:                                      */
/* UF_STYLER_callback_info_t MY_cbs */
#define MY_CB_COUNT ( 2 + 1 ) /* Add 1 for the terminator */
The following structure defines the callback entries used by the
styler file.  This structure MUST be passed into the user function,
UF_STYLER_create_dialog along with MY_CB_COUNT.
static UF_STYLER_callback_info_t MY_cbs[MY_CB_COUNT] =
{UF_STYLER_DIALOG_INDEX, UF_STYLER_APPLY_CB        , 0, MY_apply_cb},
{MY_ACTION_1           , UF_STYLER_ACTIVATE_CB     , 1, MY_import_cb},
{UF_STYLER_NULL_OBJECT, UF_STYLER_NO_CB, 0, 0 }
UF_MB_styler_actions_t contains 4 fields.  These are defined as follows:
Field 1 : the name of your dialog that you wish to display.
Field 2 : any client data you wish to pass to your callbacks.
Field 3 : your callback structure.
Field 4 : flag to inform menubar of your dialog location.  This flag MUST
          match the resource set in your dialog!  Do NOT ASSUME that changing
          this field will update the location of your dialog.  Please use the
          UIStyler to indicate the position of your dialog.
static UF_MB_styler_actions_t actions[] = {
    { "first_dlg.dlg",  NULL,   MY_cbs,  UF_MB_STYLER_IS_NOT_TOP },
    { NULL,  NULL,  NULL,  0 } /* This is a NULL terminated list */
/*---------------- MENUBAR HOOKUP HELP Example -------------------
To launch this dialog from a Unigraphics menubar, you must follow
the steps below.
1)  Add the following lines to your MenuScript file in order to
    associate a menu bar button with your dialog.  In this
    example, a cascade menu will be created and will be
    located just before the Help button on the main menubar.
    The button, FIRST_DLG_BTN is set up to launch your dialog and
    will be positioned as the first button on your pulldown menu.
    If you wish to add the button to an existing cascade, simply
    add the 3 lines between MENU LAUNCH_CASCADE and END_OF_MENU
    to your menuscript file.
    The MenuScript file requires an extension of ".men".
    Make sure that you add the extension to the file and place
    the file in your startup directory:
      $UGII_USER_DIR/startup or
      $UGII_SITE_DIR/startup or
      $UGII_VENDOR_DIR/startup directory
    Move the contents between the dashed lines to your Menuscript file.
    VERSION 120
    EDIT UG_GATEWAY_MAIN_MENUBAR
    BEFORE UG_HELP
      CASCADE_BUTTON UISTYLER_DLG_CASCADE_BTN
      LABEL Dialog Launcher
    END_OF_BEFORE
    MENU UISTYLER_DLG_CASCADE_BTN
      BUTTON FIRST_DLG_BTN
      LABEL Display first_dlg dialog
      ACTIONS first_dlg.dlg
    END_OF_MENU
2) Issue a call to the function, UF_MB_add_styler_actions from the ufsta
   user exit as shown below.  To use this call, remove the conditional
   definitions:  #ifdef MENUBAR_COMMENTED_OUT
                 #endif MENUBAR_COMMENTED_OUT
   The static structure, actions, will allow you to associate ALL of your
   dialogs and callback functions to the  menubar at once.  For example, if you
   wish to have 10 dialogs associated to 10 different buttons on the menubar,
   you may enter each dialog and callback list into the actions structure. Make
   sure that you have created a corresponding button in your MenuScript file.
   You may also have separate shared libraries, each with a ufsta user exit
   for each individual dialog.
3) Place your compiled and linked ufsta user function in
   $UGII_VENDOR_DIR/startup directory.
   NOTE:  The user function must contain the proper extension .so, .sl or .dll
   to make ensure that it is recognized by the MenuScript.  If it does not
   have the proper extension, it will NOT be recognized by MenuScript.
   The action name you have provided in your MenuScript must correspond to
   to the dialog name provided in the action structure.  This MUST match inorder
   to bind your dlg file to your MenuScript button.
4) Copy your UIStyler dialog file to the proper directory.
   All dialog files (.dlg) must be located in
      $UGII_USER_DIR/application or
      $UGII_SITE_DIR/application or
      $UGII_VENDOR_DIR/application directory
extern void ufsta (char *param, int *retcode, int rlen)
    int  error_code;
    if ( (UF_initialize()) != 0)
          return;
    if ( (error_code = UF_MB_add_styler_actions ( actions ) ) != 0 )
          char fail_message[133];
          UF_get_fail_message(error_code, fail_message);
          printf ( "%s\n", fail_message );
    UF_terminate();
    return;
  /*MENUBAR_COMMENTED_OUT*/
/*-------DIALOG CREATION FROM A CALLBACK HELP Example ----------
If you wish to have this dialog displayed from the callback of
another UIStyler dialog, you should:
1) Make sure that the callback of your UIStyler dialog is
   designated as a dialog building callback.
2) Remove the conditional definitions:
   #ifdef DISPLAY_FROM_CALLBACK
   #endif DISPLAY_FROM_CALLBACK
3) Your callback should issue a call to this function.
4) You should also add the funcitonal prototype to your header file
   (first_dlg.h) and ensure that the file is properly included.
All dialog files must be located in
extern int <enter the name of your function> ( int *response )
    int  error_code = 0;
    if ( ( error_code = UF_initialize() ) != 0 )
           return (0) ;
    if ( ( error_code = UF_STYLER_create_dialog ( "first_dlg.dlg",
           MY_cbs,      /* Callbacks from dialog */
           MY_CB_COUNT, /* number of callbacks*/
           NULL,        /* This is your client data */
           response ) ) != 0 )
          /* Get the user function fail message based on the fail code.*/
          UF_UI_set_status (fail_message);
    UF_terminate();
    return (error_code);
#endif /* DISPLAY_FROM_CALLBACK */
/*-------DIALOG CREATION FROM A USER EXIT HELP Example --------
To create this dialog from a user exit, you must invoke a
call to the NX Open API, UF_STYLER_create_dialog.  An example
is shown below.
1) Remove the conditional definitions:
   #endif DISPLAY_FROM_USER_EXIT
2) Add a user exit to the function name below, for example, ufusr.
3) Consider how your shared library will be unloaded.  Take a look
   at the generated function ufusr_ask_unload.
extern void ufusr (char *param, int *retcode, int rlen)
    int  response   = 0;
    int  error_code = 0;
    if ( ( UF_initialize() ) != 0 )
           return;
           &response ) ) != 0 )
    UF_terminate();
    return;
This function specifies how a shared image is unloaded from memory
within Unigraphics. This function gives you the capability to unload an
internal NX Open application or user  exit from Unigraphics.  You can
specify any one of the three constants as a return value to determine
the type of unload to perform:  immediately after user function
execution, via an unload selection dialog, or when Unigraphics terminates
terminates.  If you choose UF_UNLOAD_SEL_DIALOG, then you have the
option to unload your image by selecting  File->Utilities->Unload Shared
Image.
NOTE:  A program which associates NX Open applications with the menubar
MUST NOT use this option since it will UNLOAD your NX Open application image
from the menubar.
extern int ufusr_ask_unload (void)
     /* unload immediately after application exits*/
     return ( UF_UNLOAD_IMMEDIATELY );
     /*via the unload selection dialog... */
     /*return ( UF_UNLOAD_SEL_DIALOG );   */
     /*when UG terminates...              */
     /*return ( UF_UNLOAD_UG_TERMINATE ); */
You have the option of coding the cleanup routine to perform any housekeeping
chores that may need to be performed.  If you code the cleanup routine, it is
automatically called by Unigraphics.
extern void ufusr_cleanup (void)
    return;
/*---------------------- UIStyler Callback Functions ----------------------*/
* Callback Name: MY_apply_cb
* This is a callback function associated with an action taken from a
* UIStyler object.
* Input: dialog_id   -   The dialog id indicate which dialog this callback
*                        is associated with.  The dialog id is a dynamic,
*                        unique id and should not be stored.  It is
*                        strictly for the use in the NX Open API:
*                               UF_STYLER_ask_value(s)
*                               UF_STYLER_set_value
*        client_data -   Client data is user defined data associated
*                        with your dialog.  Client data may be bound
*                        to your dialog with UF_MB_add_styler_actions
*                        or UF_STYLER_create_dialog.
*        callback_data - This structure pointer contains information
*                        specific to the UIStyler Object type that
*                        invoked this callback and the callback type.
int MY_apply_cb ( int dialog_id,
             void * client_data,
             UF_STYLER_item_value_type_p_t callback_data)
     /* Make sure User Function is available. */
     if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
     /* ---- Enter your callback code here ----- */
     UF_terminate ();
    /* Callback acknowledged, do not terminate dialog                 */
    /* A return value of UF_UI_CB_EXIT_DIALOG will not be accepted    */
    /* for this callback type.  You must respond to your apply button.*/
    return (UF_UI_CB_CONTINUE_DIALOG);
* Callback Name: MY_import_cb
* UIStyler object.
int MY_import_cb ( int dialog_id,
             void * client_data,
     UF_terminate ();
    /* or Callback acknowledged, terminate dialog.    */
    /* return ( UF_UI_CB_EXIT_DIALOG );               */
发表于 2009-6-28 21:55:23 | 只看该作者
不要把 ufsta打开
发表于 2009-6-29 09:34:17 | 只看该作者
还是把你的程序相关内容全部打包上传,这样才好看问题所在。
发表于 2009-11-19 18:46:51 | 只看该作者
没那么复杂吧
  看你是生成那种文件格式了 ,还有  你的VC中的设置都对了吗?
GMT+8, 2025-9-18 12:23 , Processed in 0.048468 second(s), 13 queries , Gzip On, Redis On.
