查看: 15785|回复: 4
【求助】关于出错的文字提示的解释
发表于 2003-6-14 19:15:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
::y::y::y::y第一个
*** Internal error in function wf3gcscutil/wf3gcsc_QueryUnderlyingEntit
*** - gm3cvms returned a 39549 when called by
***     wf3gcscutil/wf3gcsc_QueryUnderlyingEntit at position 880
History processing stopped due to failures when replaying
the node/leaf listed above.
发表于 2003-6-14 19:16:11 | 只看该作者
::y::y::y第二个
There is no valid target to project onto
There is geometry used as a projection target that
is out of date
发表于 2003-6-14 19:17:22 | 只看该作者
::y::y::y::y::y第三个
Selected:
"齿轮箱:;0,Main"
FEA Extrude84
Deleting feature    : Extrude84
Warning: Feature Extrude108
         is referencing geometry from the selected feature.
Following nodes could not be processed.
Please try to  process them individually.
Extrude84*
0 out of 1 nodes could be processed.
发表于 2003-6-14 19:18:46 | 只看该作者
::y::y::y::y第四个
Selected:
"齿轮箱:;0,Main"
FEA Extrude84
See "Filter..." for more details.
The selected entity:
"齿轮箱:;0,Main"
FEA Scratch1
It did not pass filter criteria: Feature Type
Entity does not pass selection filter
"齿轮箱:;0,Main"
C 6456
It did not pass filter criteria: WF Curve Type
发表于 2003-6-14 19:22:39 | 只看该作者
::y::y::y::y::y
这就是出错时的操作步骤
GMT+8, 2025-4-30 12:40 , Processed in 0.028338 second(s), 12 queries , Gzip On, Redis On.
