查看: 18205|回复: 7
[已解决] 这样的后处理错误!要改那里?
发表于 2009-7-29 00:30:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这样的后处理错误!要改那里?
我另外一个后处理,处理出的就没问题!我对了一下两后处理的EXF件的那些代码都是一样的!但处理出来就不一样!
P000100
M00 (Error: ucs rotation was found)
M00 (TP=TP_UCS16 PROC=6 - PROFILE )
N10 (日期2009-7-26 -- 时刻4:4)
N12 (档案名称ca_nc.pfm)
N14 (程式名称TP_UCS16.NC)
N16 (刀具名称D16R0.8刀径16.刀尖R角0.8)
N18 (曲面偏移曲面公差轮廓偏移0)
N20 G00
N22 G17
N24 G40
N26 G71
N28 G90
N30 G92
N32 G54
N34 G09
N36 S1000 M03
N38 G00 X-565. Y0
N40 Z-230.
N42 Z-181.
N44 G01 Z-180. F105
N46 X-567. F350
N48 Y383.6
N50 Y392. F263
发表于 2009-7-29 00:39:01 | 只看该作者
这是处理上面程式的后处理!会改后处理的老师傅,能否说一下改那里!
在IT 用都没问题的,坐标怎样转都可以,到E里就不行了!
* DEMO 3 axes Post Processor for FANUC
* CIMATRON90 VER 9.0
* Last update : 23-FEB-1998
* define private variables:
FORMAT (SEQUENCING)  Seq SubSeq MaxSeq CNTRL_NUM NURBS_DEG count first deg ;
FORMAT (TOOL)        FirstTool LastTool ;
FORMAT (COORDINATES) Xold Yold Zold DXcenter DYcenter DZcenter ;
FORMAT (COORDINATES) Zinit Clear Depth CNTRL_X  CNTRL_Y  CNTRL_Z  KNOT_ ;
FORMAT (COORDINATES) Xhome Yhome Zhome ;
FORMAT (COORDINATES) XfirstOrigin YfirstOrigin ZfirstOrigin ;
FORMAT (USER_1)      CurrSubNum ;
FORMAT (COORDINATES) ORIGOLDI ORIGOLDJ ORIGOLDK ;
FORMAT (USER_4) CycleP Para ;
* define private flags:
FORMAT (USER_2)      FlagSub FlagSpin FlagCycle;
FORMAT (USER_2)      FirstOriginChange FlagError Flagrotmac  ;
* define private constants:
FORMAT (USER_2)      YES NO ;
* change the format of existing variables:
FORMAT (USER_1)      SUB_NUMBER ;
INTERACTION (USER_1)       "Program-Number"             MainNum     = 100  ;
INTERACTION (SEQUENCING)   "Start-Block-Number"   SeqStart    = 10   ;
INTERACTION (SEQUENCING)   "Block-Number-Incr"          SeqIncr     = 2    ;
INTERACTION (USER_3)       "Part-Position-Offset" ZDM         = 54   ;
INTERACTION (USER_3)       "Metric/Inch"                 METRIC      = 71   ;
INTERACTION (USER_3)       "Abs/Incr"             ABS         = 90   ;
INTERACTION (USER_3)       "Plane-Selection"             PLANE       = 17   ;
INTERACTION (USER_3)       "Tool-Compensation"    TOFF        = 40   ;
NON_MODAL  ALL_VAR;
MODAL      X_CURPOS Y_CURPOS Z_CURPOS ;
MODAL      LIN_MOV CIRC_MOV MCH_FEED SPIN_SPEED SPIN_DIR MCH_COOL MCH_DWELL;
MODAL      CUTCOM_ON  CUTCOM_OFF ;
MODAL      CYC_DEPTH CYC_PECK CYC_DWELL CYC_RETR CYC_CLEAR Depth Clear NURBS_MOV;
IDENTICAL  X_CURPOS X_ENDPT ;
IDENTICAL  Y_CURPOS Y_ENDPT ;
NEW_LINE_IS $ ;
         IF_SET (FlagSub _EQ_ NO)
            IF_SET (FlagCycle _EQ_ YES)
                OUTPUT \J "*N" Seq ;
                IF_SET (Seq _GT_ MaxSeq)
                        Seq = SeqStart ;
                ELSE
                        Seq = Seq + SeqIncr ;
                END_IF ;
            ELSE
                    OUTPUT \J "N" Seq ;
                        Seq = SeqStart ;
                ELSE
                END_IF ;
            END_IF ;
         ELSE
            OUTPUT \J "N" SubSeq ;
            SubSeq = SubSeq + SeqIncr ;
         END_IF ;
BEGINNING OF TAPE:
      YES              = 1 ;
      NO               = 0 ;
      Seq              = SeqStart ;
      Para             = 1000 ;
      FlagSub = NO ;
      FlagCycle = NO ;
      MaxSeq = 999999 - SeqIncr ;
      SET_ON  NO_SUBROUT ;
*-----tool location is HOME
      Xold = X_HOME ;
      Yold = Y_HOME ;
      Zold = Z_HOME ;
*-----For 1st ORIGIN CHANGE
      FirstOriginChange = YES ;
*-----user define batch file------
      PRINT0 \J "@ECHO ON" ;
      PRINT0 \J "MD\NC\" PART_NAME ;
      PRINT0 \J "COPY " PART_NAME "." TP_NAME ".hi800 \NC\" PART_NAME "\" TP_NAME ".NC > NUL" ;
      PRINT0 \J "DEL " PART_NAME "." TP_NAME ".hi800" ;
      PRINT0 \J "DEL " PART_NAME "." TP_NAME ".TOOLS" ;
*-----output
      OUTPUT \J "%" ;
      OUTPUT \J "P" MainNum  ;
*-----OUTPUT $ " (PARTNAME-" PART_NAME ")" ;
*--For the first origin change
   ORIGOLDI=0 ; ORIGOLDJ=0 ; ORIGOLDK=1 ;
   flagrotmac = no ;
END OF TAPE:
   OUTPUT $ " H0 " ;
   OUTPUT $ " M5 " ;
   OUTPUT $ " M9 " ;
   OUTPUT $ " M30 " \J;
FEED:
     KEEP MCH_FEED ;
SPIN:
     KEEP SPIN_SPEED ;
COOLANT:
     KEEP MCH_COOL ;
DWELL:
     KEEP MCH_DWELL ;
CUTTER COMPENSATION:
     KEEP  CUTCOM_ON ;
CUTTER COMPENSATION: COFF:
     KEEP  CUTCOM_OFF ;
TOOL CHANGE: FIRST:
      SET_ON SPIN_DIR SPIN_SPEED Z_CURPOS MCH_COOL ;
      OUTPUT $ " (日期" DATE_SYY "-" DATE_SMM "-"  DATE_SDD " -- 时刻"  TIME_SHH ":" TIME_SMM ")" ;
      OUTPUT $ " (档案名称"  PART_NAME   ".pfm)" ;
      OUTPUT $ " (程式名称"TP_NAME".NC)" ;
      OUTPUT $ " (刀具名称" CURR_NAME "刀径" DIAMETER_ "刀尖R角" TOOL_RAD ") " ;
      OUTPUT $ " (曲面偏移" PART_OFST "曲面公差" PART_TOL "轮廓偏移" CONT_OFST ") " ;
      OUTPUT $ " G00 ";
      OUTPUT $ " G17 ";
      OUTPUT $ " G40 ";
      OUTPUT $ " G71 ";
      OUTPUT $ " G90 ";
      OUTPUT $ " G92 ";
      OUTPUT $ " G54 ";
      OUTPUT $ " G09 ";
      SET_ON CURR_TOOL ZDM ;
      OUTPUT $ " S" SPIN_SPEED " " SPIN_DIR  ;
TOOL CHANGE:
      OUTPUT $ " M05" ;
      OUTPUT $ " M01" ;
      OUTPUT $ " H1"  ;
      OUTPUT $ " " MCH_COOL ;
       OUTPUT $ " G" ZDM ;
LINEAR MOTION: FAST:
      IF_SET (CUTCOM_ON)  OUTPUT $ " "  CUTCOM_ON " D" CURR_TOOL ; END_IF ;
      IF_SET (CUTCOM_OFF) OUTPUT $ " "  CUTCOM_OFF ; END_IF ;
      OUTPUT $ ;
      IF_SET (LIN_MOV)  OUTPUT " " LIN_MOV   ; END_IF ;
      IF_SET (X_CURPOS) OUTPUT " X" X_CURPOS ; END_IF ;
      IF_SET (Y_CURPOS) OUTPUT " Y" Y_CURPOS ; END_IF ;
      OUTPUT $ ;
      IF_SET (Z_CURPOS) OUTPUT " Z" Z_CURPOS ; END_IF ;
      SET_ON CIRC_MOV NURBS_MOV ;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
LINEAR MOTION:
      OUTPUT $ ;
      IF_SET (MCH_FEED)   OUTPUT " F" MCH_FEED   ; END_IF ;
      SET_ON CIRC_MOV NURBS_MOV;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CIRCULAR MOTION:
      DXcenter = X_CENTER - Xold ;
      DYcenter = Y_CENTER - Yold ;
      DZcenter = Z_CENTER - Zold ;
      OUTPUT $ ;
      IF_SET (CIRC_MOV)          OUTPUT " " CIRC_MOV  ; END_IF ;
      IF_SET (X_CURPOS)          OUTPUT " X" X_ENDPT  ; END_IF ;
      IF_SET (Y_CURPOS)          OUTPUT " Y" Y_ENDPT  ; END_IF ;
      IF_SET (Z_CURPOS)          OUTPUT " Z" Z_ENDPT  ; END_IF ;
      IF_SET (DXcenter _NE_ 0.0) OUTPUT " I" DXcenter ; END_IF ;
      IF_SET (DYcenter _NE_ 0.0) OUTPUT " J" DYcenter ; END_IF ;
      IF_SET (DZcenter _NE_ 0.0) OUTPUT " K" DZcenter ; END_IF ;
      SET_ON LIN_MOV NURBS_MOV ;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CYCLE: ON:
      SET_ON X_CURPOS Y_CURPOS Z_CURPOS   ;
      SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED MCH_COOL ;
      SET_ON Zinit Depth Clear ;
      Zinit    = Z_CURPOS + CYC_DZINIT ;
      Depth    = Z_CURPOS - CYC_DEPTH ;
      Clear    = Z_CURPOS + CYC_CLEAR ;
      IF_SET (Zold _LT_ Zinit) OUTPUT $ "G00 Z" Zinit ; END_IF ;
      IF_SET (MCH_FEED)   OUTPUT $ " F" MCH_FEED   ; END_IF ;
      FlagCycle = YES ;
      CycleP= Clear * 1000 ;  OUTPUT $ " P2=" CycleP ; SET_OFF Clear ;
      CycleP= Depth * 1000 ;  OUTPUT $ " P3=" CycleP ; SET_OFF Depth ;
      CycleP= Zinit * 1000 ;  OUTPUT $ " P10=" CycleP ; SET_OFF Zinit ;
      IF_SET (CYC_PECK)
               CycleP= CYC_PECK * 1000 ;  OUTPUT $ " P1=" CycleP ; SET_OFF CYC_PECK ;
        CycleP= CYC_PECK * 1000 ;  OUTPUT $ " P5=" CycleP ; SET_OFF CYC_PECK ;
        CycleP= CYC_REDUC * 1000 ; OUTPUT $ " P6=" CycleP ; SET_OFF CYC_REDUC ;
      END_IF ;
      IF_SET (CYC_DWELL)
              CycleP= CYC_DWELL * 1000 ; OUTPUT $ " P4=" CycleP ; SET_OFF CYC_DWELL ;
      END_IF ;
      IF_SET (CYC_XSHFT)
        CycleP= CYC_XSHFT * 1000 ; OUTPUT $ " P8=" CycleP ; SET_OFF CYC_XSHFT ;
      END_IF ;
      IF_SET (CYC_YSHFT)
        CycleP= CYC_YSHFT * 1000 ; OUTPUT $ " P9=" CycleP ; SET_OFF CYC_YSHFT ;
      END_IF ;
        CycleP= MCH_FEED * 1000 ;
        para = SPIN_SPEED;
        CycleP=CycleP/para ;
        OUTPUT $ " P99=" CycleP ;
      FlagCycle = NO ;
      OUTPUT $ ;
      OUTPUT " "  CYC_CODE ;
      SET_OFF CYC_CODE ;
      SET_ON  LIN_MOV CIRC_MOV ;
      SET_OFF CYC_DEPTH CYC_CLEAR;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CYCLE:
      FlagCycle = YES ;
      IF_SET (Clear)
        SET_OFF Clear ;
      END_IF ;
      IF_SET (Depth)
        SET_OFF Depth ;
      END_IF ;
      IF_SET (Zinit)
        SET_OFF Zinit ;
      END_IF ;
      IF_SET (CYC_PECK)
      END_IF ;
      IF_SET (CYC_DWELL)
      END_IF ;
      IF_SET (CYC_XSHFT)
      END_IF ;
      IF_SET (CYC_YSHFT)
      END_IF ;
      FlagCycle = NO ;
      OUTPUT $ ;
      IF_SET (CYC_CODE)   OUTPUT " "  CYC_CODE ; END_IF ;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CYCLE: OFF:
      OUTPUT $ " G80" ;
      SET_ON Zinit ; OUTPUT $ " G0 Z" Zinit ;
      SET_ON  LIN_MOV CIRC_MOV CYC_CODE;
      Zold = Zinit ;
ORIGIN CHANGE:
*-----Save the first origin data for later use
   IF_SET (FirstOriginChange _EQ_ YES )
         XfirstOrigin      = X_ORIGIN  ;
         YfirstOrigin      = Y_ORIGIN  ;
         ZfirstOrigin      = Z_ORIGIN  ;
         FirstOriginChange = NO        ;
   END_IF ;
*.....distance between the rotation center and the ORIGIN
      TRANS_MATX = X_ORIGIN - XfirstOrigin - X_MACH  ;
      TRANS_MATY = Y_ORIGIN - YfirstOrigin - Y_MACH  ;
      TRANS_MATZ = Z_ORIGIN - ZfirstOrigin - Z_MACH  ;
*.....check for change in orientation ( 4,5 axis positioining )
    FlagError  = NO ;
    Flagrotmac = no ;
   IF_SET ( I_ORIGIN _NE_ ORIGOLDI ) FLAGROTMAC = YES ; END_IF ;
   IF_SET ( J_ORIGIN _NE_ ORIGOLDJ ) FLAGROTMAC = YES ; END_IF ;
   IF_SET ( K_ORIGIN _NE_ ORIGOLDK ) FLAGROTMAC = YES ; END_IF ;
   IF_SET ( FLAGROTMAC _EQ_ YES )     FlagError  = YES ; END_IF ;
   IF_SET (FlagError _EQ_ YES)
       PRINT  \J "Error: ucs rotation was found in:" ;
       PRINT  \J "       TP=" TP_NAME " PROC=" PROC_NUM " (" PROC_NAME ")" ;
       PRINT  \J "Error: Cannot post ucs rotaion toolpaths" ;
       OUTPUT \J " M00 (Error: ucs rotation was found)" ;
       OUTPUT \J " M00 (TP=" TP_NAME " PROC=" PROC_NUM " - " PROC_NAME ")" ;
   END_IF ;
   ORIGOLDI = I_ORIGIN ;
   ORIGOLDJ = J_ORIGIN ;
   ORIGOLDK = K_ORIGIN ;
AXISCHANGE:
    FlagError  = NO ;
    IF_SET (AXIS_NUM  _GT_ 3)         FlagError = YES ; END_IF ;
       PRINT  \J "Error: 4/5 axes motion was found in:" ;
       PRINT  \J "Error: Cannot post 5 axes toolpaths" ;
       OUTPUT \J " M00 (Error: 4/5 axes motion was found)" ;
    END_IF ;
发表于 2009-7-29 10:09:10 | 只看该作者
老师傅都比较忙,所以我们这些菜鸟,只能等到老师傅能抽空来瞧瞧,最好瞧的时候能帮你一下,帮顶了
发表于 2009-7-29 18:40:06 | 只看该作者
帮顶了
发表于 2009-7-30 00:07:04 | 只看该作者
今天上午摸索了一下,知道在那改了,现在处理程式没问题了
发表于 2009-7-30 11:00:30 | 只看该作者
哥们 比较牛啊
发表于 2012-9-28 15:14:32 | 只看该作者
怎么改的啊
发表于 2012-10-20 23:29:11 | 只看该作者
顶起,又学了
GMT+8, 2025-4-6 16:09 , Processed in 0.027904 second(s), 13 queries , Gzip On, Redis On.
