查看: 15820|回复: 4
[求助] IT,DRILL,G99,POST
发表于 2009-8-26 16:42:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
好象参数没什么问题
发表于 2009-8-26 16:43:40 | 只看该作者
发表于 2009-8-26 16:44:21 | 只看该作者
O0100
/G5.1Q1
( 16R0 )
( 刀径=16. )
( R角=0.0 )
G90 G80 G00 G17 G40 G54
Z100. S250 M03
G98 G81 X-375. Y-120. Z-72.8 R-55.8 F25 M09
X375.
G99 X505.007 Y420.008 Z13.2 R30.2
X-505.007
G80 Z14.
M30
发表于 2009-8-26 16:47:06 | 只看该作者
CYCLE: ON:
      FlagSpin = NO ;
      IF_SET (SPIN_SPEED) FlagSpin = YES ; END_IF ;
      IF_SET (SPIN_DIR)   FlagSpin = YES ; END_IF ;
      IF_SET (FlagSpin _EQ_ YES)
         SET_ON SPIN_SPEED SPIN_DIR ;
         OUTPUT $ " S" SPIN_SPEED " " SPIN_DIR ;
      END_IF ;
      SET_ON X_CURPOS Y_CURPOS Z_CURPOS   ;
      SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED MCH_COOL ;
      SET_ON Zinit Depth Clear ;
      Zinit    = Z_CURPOS + CYC_DZINIT ;
      Depth    = Z_CURPOS - CYC_DEPTH ;
      Clear    = Z_CURPOS + CYC_CLEAR ;
      IF_SET (Zold _LT_ Zinit) OUTPUT $ " Z" Zinit ; END_IF ;
                         OUTPUT $ ;
                         OUTPUT " "  CYC_RETR ;
                         OUTPUT " "  CYC_CODE ;
                         OUTPUT " X" X_CURPOS ;
                         OUTPUT " Y" Y_CURPOS ;
                         OUTPUT " Z" Depth    ;
                         OUTPUT " R" Clear ;
      IF_SET (CYC_PECK)  OUTPUT " Q" CYC_PECK  ; END_IF ;
      IF_SET (CYC_DWELL) OUTPUT " P" CYC_DWELL ; END_IF ;
      IF_SET (CYC_XSHFT) OUTPUT " I" CYC_XSHFT ; END_IF ;
      IF_SET (CYC_YSHFT) OUTPUT " J" CYC_YSHFT ; END_IF ;
                         OUTPUT " F" MCH_FEED ;
                         OUTPUT " "  MCH_COOL ;
      SET_ON  LIN_MOV CIRC_MOV ;
      SET_OFF CYC_DEPTH CYC_CLEAR;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CYCLE:
      OUTPUT $ ;
      IF_SET (CYC_RETR)   OUTPUT " "  CYC_RETR   ; END_IF ;
      IF_SET (X_CURPOS)   OUTPUT " X" X_CURPOS   ; END_IF ;
      IF_SET (Y_CURPOS)   OUTPUT " Y" Y_CURPOS   ; END_IF ;
      IF_SET (Depth)      OUTPUT " Z" Depth      ; END_IF ;
      IF_SET (Clear)      OUTPUT " R" Clear      ; END_IF ;
      IF_SET (SPIN_SPEED) OUTPUT " S" SPIN_SPEED ; END_IF ;
      IF_SET (SPIN_DIR)   OUTPUT " "  SPIN_DIR   ; END_IF ;
      IF_SET (MCH_FEED)   OUTPUT " F" MCH_FEED   ; END_IF ;
      IF_SET (MCH_COOL)   OUTPUT " "  MCH_COOL   ; END_IF ;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CYCLE: OFF:
      OUTPUT $ " G80 Z" Zinit ;
      Zold = Zinit ;
这个Zinit 我一直想去掉的,但不知有无问题,请高手指正,那个G99请问怎么处理好??
发表于 2009-8-26 19:43:51 | 只看该作者
G99在这里和G98的区别在于
G99钻好一个孔后,回到R值直接走下一个孔
G98钻好一个孔后,回到钻孔循环指令上面一个Z值的高度加工下一个。
再警告一下,初始位置最好设高点,如果有不同高度的孔,钻孔时最好先点高处的,深处的最后点,再最后注意检查后处理,注意G80后面的Z值,血淋淋的教训
GMT+8, 2025-10-19 01:35 , Processed in 0.426600 second(s), 10 queries , Gzip On, Redis On.
