查看: 22792|回复: 8
[讨论] moldflow2010中文语言包显示乱码
发表于 2009-8-28 22:43:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教大家一个问题:
安装moldflow2010后,工作区的结果显示的都是乱码,不知道如何解决?
我安装的模块有:MPI2010+中文语言包、Adviser2010+中文语言包、MDL2010、CAD doctor2010;
都可以正常使用,在切换到中文语言时,MPI和Adviser都有结果显示乱码的问题。
在英文模式下一切正常。
系统是windows7旗舰版32位,难道和这个有关么?
乱码部分见下图。
发表于 2009-8-29 09:37:58 | 只看该作者
可能是2010对win7 的兼容性不好
发表于 2009-8-29 12:39:34 | 只看该作者
lizhaomin 发表于 2009-8-29 09:37
可能是2010对win7 的兼容性不好
不是这个原因,我也是WIN7 X64 上安装的moldflow 2010R2_sp1没发现这个小问题
发表于 2009-8-30 15:06:16 | 只看该作者
你的系统是什么版本的 ?如果安装的繁体版的系统,有可能会导致简体软件乱码。
发表于 2009-11-8 14:51:34 | 只看该作者
我的分析完以后也出现都是乱码,不知你的moldflow 2010R2_sp1 是在那下载的。
可否共享一下呢.
发表于 2009-11-10 13:53:50 | 只看该作者
可否共享一下呢.
I’m pleased to announce the availability of Autodesk Moldflow Insight 2010 Release 2, Service Pack 1. The service pack is available through Auto-Update for customers that start Autodesk Moldflow Insight 2010 Release 2 and on Subscription Center.
Customers on active subscription can download Autodesk Moldflow Insight 2010 Release 2 Service pack 1 from Autodesk Subscription Center (www.subscription.autodesk.com). Once logged in, click on ‘Product Downloads’ on the left hand side of the screen. Then follow the links to the available Moldflow 2010 Release 2 Service Pack 1 products. The Autdesk Moldflow 2010 Release 2 Service Pack 1 requires Autodesk Moldflow 2010 Release 2 products to be installed as a base.
The major enhancements for the service pack are:
• Speed improvement and memory reduction for 3D Fill +Pack solver. The performance improvements are available for both single threaded and parallel analysis.
• Improved exit behavior in case a 3D Fill + Pack analysis has insufficient memory available.
• Resolved a problem in the temperature calculation for cases where there polymer flowed from
tetrahedral elements into beam elements.
• A solver and screen output fix for 3D gas assisted injection molding.
• Resolved an issue in Dual Domain meshing where properties assigned to the CAD model were not transferred to the Dual Domain mesh.
• Improvements in behavior for the Customer Error Reporting (CER) and the Customer Involvement Program (CIP).
发表于 2009-11-10 18:16:14 | 只看该作者
不懂。在学习当中。
发表于 2009-12-23 12:37:09 | 只看该作者
我在WIN7安装不上不知怎么回事
发表于 2013-11-19 10:47:31 | 只看该作者
同求!
GMT+8, 2025-4-12 11:59 , Processed in 0.034308 second(s), 13 queries , Gzip On, Redis On.
