查看: 21433|回复: 3
[求助] CAA百科全书use case 编译没有结果,请高手帮忙看看
发表于 2009-9-3 15:42:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
use case 编译没有结果,是否是环境设置的问题?
运行CAADoc中最基本的一个模块CAAApplicationFrame.edu\CAAAfrGeoCreationWbench.m,有这样的问题:
首先在Locate Prerequisite Workspaces... :的时候出现:
# mkmk-ERROR: CAASystem.edu -> This Framework was not found in specified Workspace(s).
# mkmk-ERROR: CAAVisualization.edu -> This Framework was not found in specified Workspace(s).
CATIA的安装路径是D:\CATIA\B14
CAAApplicationFrame.edu拷贝到了E:\CAA\TEST1
其次在MKMK的时候出现一样的错误提示,
UPDATE的时候出现## start step: DataUpdate   at 08/31/2009-14:41:49
## end   step: DataUpdate   at 08/31/2009-14:41:49
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrCustomizedCommandHeader.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeneralWksAddin.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoAnalysisWbench.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoCommands.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoCreationWkbAddin.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoDocument.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoEdition.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeometryWksTransition.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeometryWshop.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoModel.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGEOSubMenu.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoWindows.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoWksAddin.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrGeoWksAddin2.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrInitialWorkbench.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrPaletteOptions.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrProductLine.m has no module.data asso
ciated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrProgressTask.m has no module.data associated.
# mkmk-ERROR: In framework CAAApplicationFrame.edu module CAAAfrSampleDocument.m has no module.data associated.
# mkmk-ERROR: Unable to load one or more module.data for framework [CAAApplicationFrame.edu].
运行的时候没有结果,出不来百科全书上显示的界面
不知道是不是环境变量设置的不对,求好心人解答!!!
我照着Building and Launching a CAA V5 Use Case里VC++部分一步步做的,前面Step-by-Step with Windows没有弄明白,是不是就是少了这个不行啊?
发表于 2016-1-12 19:41:40 | 只看该作者
楼主解决了吗  我遇到这个错误是什么情况
# mkmk-ERROR: In framework MyFrame module MyModule1.m has no module.data associated.
# mkmk-ERROR: In framework MyFrame module MyWorkbench.m has no module.data associated.
# mkmk-ERROR: Unable to load one or more module.data for framework [MyFrame].
发表于 2017-10-17 20:50:47 | 只看该作者
Step-by-Step with Windows里面的东西感觉是DOS时代的啊 不知道如何用还??
发表于 2017-10-18 06:41:32 | 只看该作者
谢谢楼主分享……
GMT+8, 2025-4-12 14:44 , Processed in 0.023455 second(s), 13 queries , Gzip On, Redis On.
