查看: 18135|回复: 1
[求助] ADMAS求解时锁住
发表于 2009-9-21 13:41:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请大家给我翻译下面这短话。迫切需要,非常感谢!
At time  4.551652511E-01 the integrator is unable to proceed.  Possible Causes:
(1) The accuracy required for the numerical solution can not be attained.
Relax (increase) the value of the acceptable integration ERROR.
(2) Incompatible redundant constraints, a lock up, or a bifurcation
situation.  The latter two indicate a mechanism design problem.
(3) The system includes a zero (or relatively small) mass on a part with
an unconstrained translational degree of freedom.
Make sure you have mass on all parts with translational degrees of freedom.
(4) The system includes a zero (or relatively small) inertia on a part
with an unconstrained rotational degree of freedom.
Make sure you have inertias on all parts with rotational degrees of freedom.
(5) An ADAMS element has a function expression that equals exactly itself.
For example,
     SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and
     DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4).
Similarly,
     VARIABLE/id5, FUNC=VARVAL(id5)*TIME
equals itself at 1 second. Avoid setting an ADAMS element equal to itself
发表于 2009-9-26 18:17:23 | 只看该作者
模型出现自锁,需要把刚体换成柔性体,
GMT+8, 2025-4-22 13:47 , Processed in 0.022922 second(s), 11 queries , Gzip On, Redis On.
