查看: 17785|回复: 2
[分享] MOLECULAR DYNAMICS SIMULATION OF NANO-SCALE POLYMERIC RHEOLOGICAL PROPERTIES ...
发表于 2009-10-9 11:43:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MOLECULAR DYNAMICS SIMULATION OF NANO-SCALE POLYMERIC RHEOLOGICAL PROPERTIES AND EXTRUSION FLOWS
Rong-Yeu Chang*, Jenn-Jye Wang
Department of Chemical Engineering
National Tsing Hua University, HsinChu, Taiwan 30043, ROC
Abstract
In this work the rheological properties of polymer have been studied by molecular dynamics simulation. Couette flow with various shear rates are used to investigate the degree of slip, shear viscosity and normal stress difference. The fluid consists of chains of n-hexadecane and is confined between two structured gold atomic walls. Isothermal simulations (350K) of 4:1 unsteady extrusion flow with various extrusion rates are conducted.
Introduction
Rheological properties of polymer are critical for polymer process. The extrusion molding is important polymer process of nowadays. In this work the rheological properties of polymer have been studied by molecular dynamics simulation. We also develop the MD numerical analysis to simulate the polymer process. It can efficient provide more micro phenomena, such as the structure of molecule chain,  orientation…etc.
Analysis Approach
The short chain PE (C50H102) has selected as the simulated model. Shifted Lennard-Jones potential enable us to describe Van der Waals Force.
参与人数 1技术 +1 大米 +10 收起 理由
lrbheyuan + 1 + 10 我很赞同
发表于 2009-10-9 11:46:06 | 只看该作者
1# irenechen
These parameters[4] are listed in Table 1. Regarding to the analysis model of extrusion flow, the below governing equation is adopted.
The 5-order Gear predictor-corrector method is used to solve Newton’s law of motion.
Results and Discussion
The simulated model is shown in Figure 1. Fluid is composed of 576 linear C50H102 molecules. The number of particle is 28,800. The initial density is 2.35
-3. Wall molecules are composed of 3 BCC lattice layers. The
time step is 0.0005 m/  , and the direction of depth is period boundary.
The analysis results of extrusion speed 35.17 (m/s) is shown in Figure 2. The figure 3 shows the density distribution. There are fountain effects when the fluid flows through the narrow channel. The orientation of molecule chain near melt front is shown in  Figure 4. The orientations of molecule chains are perpendicular to the flow direction. However, the molecule chains near mold wall are parallel to the flow direction. The velocity field is shown in Figure 5. The flow path is shown in Figure 6. We can find the die swelling phenomena from our simulation, and the density of fluid is not uniform, which indicates that the fluid is compressible. No vertex is found in the simulation result.
发表于 2009-10-9 11:50:16 | 只看该作者
Conclusions
For the short chain PE (C50H102), we can find the die swelling phenomena from our simulation, and the density of fluid is not uniform, which indicates that the fluid is compressible. No vertex is found in the simulation result. Besides, the orientations of molecule chains are perpendicular to the flow direction. However, the molecule chains near mold wall are parallel to the flow direction.
Reference
1. S.A. White, A.D. Gotsis and D.G. baird, "Review of The Entry Flow Problem - Experimental and Numerical", J. Non-Newtonian Fluid Mech., vol.24,
pp.121-160 (1987)
2. X.-L. Luo and E. Mitsoulis, "A numerical Study of the Effect of Elongational Viscosity on Vortex Growth in Contraction Flows of Polyethylene Melts", J. Rheol., vol.34, pp.309-342 (1990)
3. Gilmar Mompean, Michel Deville, "Unsteady Finite Volume Simulation of Oldroyd-B Fluid through a Three-dimensional Planar Contraction", J. Non-Newtonian Fluid Mech. vol.72, pp.253-279 (1997)
4. A. Jabbarzadeh, J.D. Atkinson, R.I. Tanner "Nanorheology of Molecularly Thin Films of n-hexadecane in Couette Shear Flow By Molecular Dynamcis Simulation" J. Non-Newtonian Fluid Mech. vol.77 pp.53-78 (1998)
5. A. Jabbarzadeh, J. D. Atkinson, and R. I. Tanner. “Wall slip in the molecular dynamics simulation of thin films of hexadecane" Journal of Chemical Physics vol. 110 pp.2612-2620 (1999)
6. A. Jabbarzadeh, J. D. Atkinson, and R. I. Tanner. “Effect of the wall roughness on slip and rheological properties of hexadecane in molecular dynamics simulation of Couette shear flow between two sinusoidal walls” Physical Review E Vol. 61, 690-699 (2000)
7. A. Jabbarzadeh, J.D. Atkinson and R.I. Tanner"The Effect of Branching on Slip and Rheological Properties of Lubricants in Molecular Dynamics Simulation of Couette Shear Flow" Tribology International vol.35 pp.35–46 (2002)
8. J.D. Moore, S.T. Cui, H.D. Cochran, P.T. Cummings "A molecular dynamics study of a short chain polyethylene melt I. Steady state shear" J. Non-Newtonian Fluid Mech. vol.93 pp.83-99 (2000)
9. J.D. Moore, S.T. Cui, H.D. Cochran, P.T. Cummings "A molecular dynamics study of a short chain polyethylene melt II. Transient response upon onset shear" J. Non-Newtonian Fluid Mech. vol.93 pp.101-116 (2000) Key Words molecular dynamics simulation, nano scale, rheology, extrusion flow, entrance flow
GMT+8, 2025-4-25 21:22 , Processed in 0.022373 second(s), 12 queries , Gzip On, Redis On.
