查看: 17330|回复: 1
[求助] 仿真到一定位置时出现以下的错误
发表于 2009-10-10 17:02:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我做的是一个螺旋副的机器人,在刚开始运动时没有问题,但是当螺母运动到一定位置时就出现以下问题,这个问题是怎么引起的呢。希望有做这方面的一起交流。
WARNING:    The symbolic refactorization failed.  The matrix is structurally singular
   at time = 0.40088.
WARNING:    After 50 iterations of the calculations for the initial conditions, the
   mechanism has been assembled with a maximum-magnitude error of 16.869
   which does not satisfy the specified tolerance of 1.0E-10 .
   at time = 0.40088.
   at time = 0.40088.
WARNING:    ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
   NOTE:  The set of redundant constraints has changed at time = 0.40088.
发表于 2009-10-11 20:59:28 | 只看该作者
谁能解答以下。两个不相关联的万向节。为什么不能同时加上。非得去掉一个才行。都加上就会出现上面的问题。
GMT+8, 2025-4-28 02:08 , Processed in 0.020244 second(s), 11 queries , Gzip On, Redis On.
