查看: 15902|回复: 2
[求助] 请问宏是否能用c函数调用,或者是否有能回放刀路的c函数?
发表于 2009-11-19 15:05:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
要不然是否有回放刀路的grip命令!
请教各位高手,谢谢!
发表于 2009-11-19 20:53:57 | 只看该作者
给你找了一下用这个:
UF_PARAM_replay_path (view source)
Defined in: uf_param.h
Overview
This function replays the tool path for the operations associated with
the object specified by 'param_tag'. If this object is a group then the tool
paths for all operations in the group will be replayed. If the object is an
operation then the tool path for that single operation will be replayed.
Environment
Internal and External
History
Originally released in NX3
int UF_PARAM_replay_path
tag_t param_tag
发表于 2009-11-20 18:43:37 | 只看该作者
谢谢了,这是3.0的
忘了说了!必须要在2.0上开发
GMT+8, 2025-4-19 22:29 , Processed in 0.020066 second(s), 11 queries , Gzip On, Redis On.
