查看: 21737|回复: 2
[求助] 非正交机床UG后处理
发表于 2009-11-24 16:55:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
非正交五轴参数设置
机床型号 DMU 60P
将旋转方向设置成为None,用方向和角度来定义旋转轴方向
Set mom_kin_Machine_type:5_axis_haed_table.
Set mom_kin_4th_axis_place:NONE
Set mom_kin_4th_axis_center_offset(0):0.0.
Set mom_kin_4th_axis_center_offset(1):0.0.
Set mom_kin_4th_axis_center_offset(2):0.0.
Set mom_kin_4th_axis_rotation:Normal.
Set mom_kin_4th_axis_zero_position:0.0.
用余弦函数定义第四轴
Set mom_kin_4th_axis_vector(0):0.0.
Set mom_kin_4th_axis_vector(1):1.0000.
Set mom_kin_4th_axis_vector(2):1.0000.
用两个角度来定义第四轴
Set mom_kin_4th_axis_angles(0):90.0.
Set mom_kin_4th_axis_ angles (1):45.0.
旋转轴摆长参数用变量数组mom_kin_gauge_to_ pivot来定义
Set mom_kin_gauge_to_ pivot (0):XX(X-head offset).
Set mom_kin_gauge_to_ pivot (1):YY(Y-head offset).
Set mom_kin_gauge_to_ pivot (2):ZZ(Z-head offset).
Set mom_kin_5th_axis_place:NONE
Set mom_kin_5th_axis_center_offset(0):0.0.
Set mom_kin_5th_axis_center_offset(1):0.0.
Set mom_kin_5th_axis_center_offset(2):0.0.
Set mom_kin_5th_axis_rotation:Normal.
Set mom_kin_5th_axis_zero_position:0.0.
用余弦函数来定义第五轴
Set mom_kin_5th_axis_vector(0):0.0.
Set mom_kin_5th_axis_vector(1):0.0.
Set mom_kin_5th_axis_vector(2):1.0000.
用两个角度来定义第五轴
Set mom_kin_5th_axis_angles(0):0.0.
Set mom_kin_5th_axis_angles (1):0.0.
请问怎样在UG后处理里设置TCL?
在进行仿真时,对应的prt文件怎么设置调用!摸索了几天没有头绪,望高人指点迷津,感激不尽
发表于 2009-11-27 10:06:57 | 只看该作者
自己顶1下
盼望高手的帮助!
发表于 2009-11-27 11:24:04 | 只看该作者
如果不是很老的系统,后处理可以参考
D:\Program Files\UGS\NX 6.0\MACH\resource\library\machine\installed_machines\sim09_mill_5ax\postprocessor\heidenhainTNC
GMT+8, 2025-4-25 17:43 , Processed in 0.023574 second(s), 11 queries , Gzip On, Redis On.
