查看: 19365|回复: 3
[转贴] Anaglyph公司发布Laminate tools 4.0版本
发表于 2010-2-8 14:24:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Anaglyph公司发布复合材料软件Laminate tools 4.0版本
New features in Laminate Tools version 4.0  (first release, since launch of version 3.4)
Geometry
•        new module, introducing new functionality with potential for many further features
•        new STEP and IGES file format import capability
•        automatic mesh conversion with surface sew function
•        automatic Element Set creation for imported surfaces, for easy selection
Design
•        added draping warp and weft angle deviation graphics
•        implemented Element Set picking in graphics
•        corrected problems with Reverse ply application in Layup
•        re-introduced STL format import node merge tolerance, added edge sew tolerance
Manufacturing
•        added support for generation of exact innermost / outermost layup surfaces as point clouds
•        improved exact flat pattern calculations by preserving surface normals at ply edges
Analysis
•        implemented surface offset extrusion for Nastran solid elements
•        supported sandwich configurations for solid element extrusion with 3 elements through thickness
•        automated the 3D solid element stiffness property calculation and export
•        enabled Nastran/Optistruct exports to merge with any Nastran data file
•        upgraded Optistruct SET export format
•        forced laminate angles within -90..+90 for the Nastran First Ply option
•        improved support for Ansys LOCAL axis systems and Ansys Existing laminate generation
Post-processing
•        improved stiffness calculations for anisotropic materials, for interactive calculations
•        improved automatic min-max range for stress or strain contour plots
User Interface
•        enabled all windows to be considered when optimising desktop layout
•        added gradient background colour in graphics windows
•        allowed the opening of multiple files via Windows Explorer, in separate threads
•        added diagnostics for licencing operations
•        implemented licence update via user interface
•        improved status bar update for progress messages
•        implemented custom toolbar positioning
•        implemented html help in addition to standard Windows help
•        added numerous visual and efficiency improvements
发表于 2010-2-8 14:27:35 | 只看该作者
Laminate Tools + LAP, 全面的复合材料解决方案
Laminate Tools——强大的复合材料工程软件
专注于纤维增强复合材料设计,为复合材料设计、分析和制造提供无缝协作平台
模块化设计,支持工业标准文件,丰富的CAD、CAE软件接口
强大的铺层设计和可视化功能,对FEA结果进行全面深入分析,支持多种失效准则
支持平面样图生成,可自动生成激光投影数据,与制造过程无缝连接
LT的分析结果(某个网格单元的计算结果)可以导入LAP进行进一步分析;LAP的分析结果可以为LT进行铺层设计提供指导。
LAP——专业的复合材料层合板分析软件
专门针对复合材料层合板分析,适用于复合材料初步设计阶段
提供层合板优化模块,支持多种方式的剪裁和优化
可以从LT导入局部单元的FEA数据进行更详细分析
多种其他有用特性,如非线性、自定义失效准则、缺口压缩强度分析等
发表于 2010-2-8 14:27:55 | 只看该作者
LAP——专业的复合材料层合板分析软件
发表于 2010-6-13 10:48:02 | 只看该作者
不止如何挂附件?
GMT+8, 2025-4-23 15:28 , Processed in 0.020473 second(s), 12 queries , Gzip On, Redis On.
