查看: 16276|回复: 2
[讨论] 请问:求长度的函数是哪个?
发表于 2010-2-11 19:48:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问:UG OPEN FOR C求长度的函数是哪个?  我是求的是曲线的长度
发表于 2010-2-21 14:13:18 | 只看该作者
如果用.NET做的话应该是这个
measureLength = workpart.MeasureManager.NewLength(nullUnit, line_objects)
API 不是很清楚哪个。。没做过
发表于 2010-2-23 21:26:22 | 只看该作者
Computes the arc length of a curve between two input parameters.
Environment: Internal  and  External
See Also:
History:
extern UFUNEXPORT int UF_CURVE_ask_arc_length (
tag_t curve_tag ,/* <I>
                 Tag of curve to query for arc length
double start_param ,/* <I>
                    Start parameter of the curve from which the arc
                    length is to be calculated.
double end_param ,/* <I>
                  End parameter of the curve to which the arc length
UF_MODL_units_t unit_flag ,/* <I>
                           Any one of  the following enumerated constants:
               UF_MODL_UNITS_PART - same as parts units
               UF_MODL_INCH              - inches
               UF_MODL_MMETER    - millimeters
               UF_MODL_CMETER     - centimeters
               UF_MODL_METER        - meters
double* arc_length  /* <O>
                    arc length of the curve from start_param to end_param.
GMT+8, 2025-7-8 14:00 , Processed in 0.024241 second(s), 11 queries , Gzip On, Redis On.
