查看: 17547|回复: 2
[原创] 结构优化设计软件TOSCA发布7.0.1版本
发表于 2010-2-20 09:36:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
结构优化设计软件TOSCA发布7.0.1版本 We are pleased to present you the latest version of TOSCA Structure 7.0.1. TOSCA Structure 7.0.1 is a patch release with some small improvements and fixes. The main enhancements / changes: TOSCA ANSA environment: - Update to Version 13.0.3 of TOSCA ANSA environment - Import of TOSCA Structure Parameterfiles to Task Manager - Optimization Monitor including Convergence Plot, VTF generation and TOSCA.OUT viewer - Improved Highlightning - Tool Tips in preprocessing dialogs - Support of multiple cutting splines in one smooth run TOSCA Structure.topology: - Improvements of manufacturing constraints for sensitivity based topology optimization TOSCA Structure.shape: - Improved Mesh Smooth algorithm - Inner nodes are allowed in design area to ease problem definition Plattforms: - Support of Windows 7. Solver changes: The interface to PERMAS and MARC was adapted to the functionality of TOSCA Structure Release 7.0.0. This includes the support of contact definitions and displacement constraints for the sensitivity based topology optimization. For subsequent versions of TOSCA Structure these solver interfaces will be frozen with functionality of TOSCA Structure 7.0.1. The interfaces will be available in the current version as as-is interface. No further develOPMents and enhancements will be made for this interface. For more detailed information please see www.caeda.com.cn
发表于 2010-3-2 08:56:53 | 只看该作者
可以免费试用正版软件
发表于 2010-4-9 23:32:15 | 只看该作者
请问在哪里下载呢?
GMT+8, 2025-4-23 01:33 , Processed in 0.021111 second(s), 11 queries , Gzip On, Redis On.
