查看: 16494|回复: 2
[求助] 如何使用CATIMechanicalRootFactory创建特征!
发表于 2010-3-16 14:47:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
HRESULT rc;
CATFrmEditor * pEditor   = GetEditor();
if (NULL == pEditor)
  return;
CATDocument *pDoc = pEditor->GetDocument();
if (NULL == pDoc)
  return;
CATInit *spInitOnDoc = NULL;
rc = pDoc -> QueryInterface (IID_CATInit, (void**) &spInitOnDoc);
if (E_NOINTERFACE == rc)
  Notify("NoCATInit");
  return;
CATIPrtContainer *pIPrtCont = NULL ;
pIPrtCont = (CATIPrtContainer*)
  spInitOnDoc->GetRootContainer("CATIPrtContainer");
if (NULL == pIPrtCont )
  return;
  CATISpecObject_var spSpecObjectOnPart = pIPrtCont->GetPart();
if (NULL_var == spSpecObjectOnPart)
  return;
CATIMechanicalRootFactory *pIMechanicalRootFactoryOnPart = NULL ;
rc = spSpecObjectOnPart->QueryInterface(IID_CATIMechanicalRootFactory,
  (void**)&pIMechanicalRootFactoryOnPart);
if (SUCCEEDED(rc ))
  Notify("SUCCEEDED");
else if (E_FAIL == rc )
  Notify("E_FAIL == tc");
  return;
else if(E_NOINTERFACE == rc )
  Notify("E_NOINTERFACE == rc ");
  return;
在创建一个新的MechanicalTool Feature或者是Geometrical Set时,要用到CATIMechanicalRootFactory 接口,但按照上面的代码,总显示接口不存在!不知是什么原因,但可以通过CATIDesendants获得MechanicalPart下面的特征!
发表于 2010-3-22 10:18:59 | 只看该作者
楼主可以尝试一下
pIPrtCont = (CATIPrtContainer*)   spInitOnDoc->GetRootContainer("CATIPrtContainer");
  return;
CATIPrtPart_var spPrtPart( pIPrtCont->GetPart() );
再可以将它直接付给CATIMechanicalRootFactory
CATIMechanicalRootFactory_var  spMechanicalRootFactoryOnPart = spPrtPart;
再用spMechanicalRootFactoryOnPart 来创建特征。我这样实现过,楼主可以试试
发表于 2010-3-22 15:49:41 | 只看该作者
我程序里面的rc = spSpecObjectOnPart->QueryInterface(IID_CATIMechanicalRootFactory,
这段程序改为rc = pIPrtCont->QueryInterface(IID_CATIMechanicalRootFactory,
就可以了,还是谢谢你哈!
GMT+8, 2025-4-19 03:53 , Processed in 0.020925 second(s), 11 queries , Gzip On, Redis On.
