查看: 15971|回复: 0
[求助] ADAMS 仿真中遇到的问题
发表于 2010-3-26 22:42:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ERROR:      ***** ADAMS MEMORY OVERFLOW *****
   A larger MD array is required.
   The error occurred in subroutine "SYMFAC" while allocating " INTE" space
   from "TEMP" for the "JCOL array".
   Space Available:  12421    Space Requested:  51523
   ADAMS/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   20,000,000
        HUGE       60,000,000
   where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
   the main memory array in ADAMS in words (one word is 4 bytes).
   To use an alternative setting, you have to start the ADAMS 'Settings'
   program.  It can be found using the Start menu:
     Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
ERROR:   Abnormal termination encountered in ADAMS/Solver.
GMT+8, 2025-4-21 21:03 , Processed in 0.020609 second(s), 14 queries , Gzip On, Redis On.
