查看: 20318|回复: 4
[求助] 新手学习ADAMS宏命令遇到的问题
发表于 2010-4-8 19:23:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我按照书上例子做复制移动圆柱体的题目,编写的程序如下,完全是照书写的
!USER_ENTERED_COMMAND part replicate single
!HELP_STRING This command copies a part and offsets it a prescribe
!$marker_to_project_along:T=marker:C=1
!$offset_distance:T=real=50
!$which_axis:T=list(x,y,z)=Z
var cre var=$_self.tmp_mod object=(eval(DB_DEFAULT(.System_Defaults,"model")))
var cre var=$_self.tmp_name string=(eval(UNIQUE_LOCAL_NAME($_self.tmp_mod,($marker_to_project_along.parent.name))))
part copy&
     part_name=($marker_to_project_along.parent)&
     new_part_name=($_self.tmp_name)&
if cond=("$which_axis"=="x")
move object part_name=($_self.tmp_name)&
   c1=$offset_distance c2=0 c3=0&
   csmarker_name=$marker_to_project_along&
   incremental=yes
elseif cond=("$which_axis"=="y")
    c1=0 c2=$offset_distance c3=0
    incremental=yes
!elseif cond=("$which_axis"=="z")
    c1=0 c2=0 c3=$offset_distance&
    incremental=yes
end !if
var del var=$_self.*
可是执行命令时总是提示错误,求高手帮帮忙,谢谢:
ERROR:   ---------------------------------------------------------------------
ERROR:   Error detected on line number 14, character 3 of the macro '.par_rep_single'.
ERROR:   'if' is not a valid parameter.
ERROR:   The command was not executed.
ERROR:   &> if cond=("x"=="x")
ERROR:   Error detected on line number 15, character 49 of the macro '.par_rep_single'.
ERROR:    Database object "ART_2_1" does not exist
ERROR:   >> move object part_name=(.par_rep_single.tmp_name)&
ERROR:   There is no matching IF for this ELSE command.
ERROR:   Error detected on line number 21, character 49 of the macro '.par_rep_single'.
ERROR:   Error detected on line number 23, character 18 of the macro '.par_rep_single'.
ERROR:   'csmarker_name' is not a valid entity.
ERROR:   >>     csmarker_name=.model_1.PART_2.cm&
ERROR:   Error detected on line number 26, character 49 of the macro '.par_rep_single'.
ERROR:   There is no matching IF, WHILE, or FOR for this END command.
发表于 2010-4-8 19:25:28 | 只看该作者
晕,这符号整的, 其实是 :D
发表于 2011-6-15 11:00:54 | 只看该作者
新人报到,希望大家照顾
也遇到类似的问题
期待高手解答啊
发表于 2011-7-25 18:17:35 | 只看该作者
!(感叹号表示注释语句),当然会提示错误了
发表于 2012-3-27 22:07:49 | 只看该作者
同样的问题。求解释。
GMT+8, 2025-4-8 16:46 , Processed in 0.110769 second(s), 12 queries , Gzip On, Redis On.
