查看: 20363|回复: 0
[求助] Adams整车仿真失败,高手大虾们帮忙看看O(∩_∩)O谢谢
发表于 2010-5-7 09:42:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
整车模型是通过修改template模板,之后组建的。
仿真的时候出现以下提示:
Setting up the vehicle assembly for the FOUR_POST_TESTRIG...
Reading in property files...
Reading of property files completed.
Setup of the vehicle assembly is completed.
Simulation is beginning...
Starting analysis #1 of vehicle assembly...
   *                 MSC.Software Corporation                   *
   *                  A D A M S / S o l v e r                   *
   *      Automatic Dynamic Analysis of Mechanical Systems      *
   *      2010-05-07 09:29:07              Version 2005.0.0     *
   Enter ADAMS model file name or Carriage Return or ? (or STOP):
   No model input file (ADM file) is given.
   Enter Command:
   file/model=try_fourpost
   A new model supplied.  Initialization starts...
   The default input and analysis values will be restored.
   CPU time used = 0.46875 seconds
   ADAMS/Car 2005.0.0
   ID = 1
   Enter ADAMS output file name or ? (default is same as input):
     ADAMS model file .. try_fourpost.adm
   Default file names for output files
     Tabular output file:
     try_fourpost.out
     Diagnostic file    :
     try_fourpost.msg
     Message Database file    :
     try_fourpost.mdb
     Graphics file      :
     try_fourpost.gra
     Request file       :
     try_fourpost.req
     Results file       :
     try_fourpost.res
   Input Phase - Reading in Model
   ADAMS/Solver dataset Title:
   ADAMS/Car Assembly (v2005.0.0)
   Reading of model complete.
   Input Phase - Populating Solver database
   Input Phase Complete.
   CPU time is 0.46875 seconds.
   Input and Input Check Phase complete.
   The system has 20 kinematic degrees of freedom.
   Enter Command:
   preferences/solver=F77
   Enter Command:
   output/nosep
   Enter Command:
   equilibrium/ stability=1.0e-4
   Enter Command:
   diff/2, fun=0
   Enter Command:
   diff/3, fun=0
   Enter Command:
   diff/5, fun=0
   Enter Command:
   diff/4, fun=0
   Enter Command:
   simulate/statics
   Current ADAMS model successfully verified.
   Entering the static equilibrium analysis phase...
   Displacement initial condition analysis...
   Jacobian Matrix Statistics for the Initial Conditions
   Number of equations ............. = 604
   Number of non-zero entries ...... = 4284
   Percentage of matrix non-zero ... = 1.1743
   Total space used in MD array .... = 376308
Reading configuration file 'd:\MSC.Software\MSC.ADAMS\2005\acar/acar.cfg'
Reading configuration file 'C:\Documents and Settings\Administrator/.acar.cfg'
Reading configuration file 'd:\MSC.Software\MSC.ADAMS\2005\aride/aride.cfg'
       TIRE ID:  1
       TYR900 -> Pacejka 89 Tire Model
       Using 2D Handling Road Contact v1.0
       TIRE ID:  2
       TIRE ID:  3
       3D Contact:
       SHAPE table not found in tire property file.
       Tire carcass shape defaults to a cylinder.
       TIRE ID:  4
       3D Contact:
   Performing Static analysis...
   Generating the Jacobian matrix for the statics or quasi-statics problem.
   Jacobian Matrix Statistics for Statics
   Number of equations ............. = 1645
   Number of non-zero entries ...... = 16835
   Percentage of matrix non-zero ... = 0.62213
   Total space used in MD array .... = 694796
   Symbolic refactorization attempted at time = 0.0.
   Static equilibrium was found after 6 iterations.
   The maximum error is 1.28960E-05 with a maximum imbalance of 4.12865E-09.
   Enter Command:
   deactivate/jprim, id=6
   Enter Command:
   deactivate/jprim, id=7
   Enter Command:
   simulate/dynamics, end=10.0, steps=4000
   The system has 23 kinematic degrees of freedom.
   Begin the dynamic analysis.
   The system is modelled with INDEX-3 DAEs.
   The integrator is GSTIFF, CORRECTOR=original.
   Integration error = 1.0E-02
   Number of equations ............. = 601
   Number of non-zero entries ...... = 4254
   Percentage of matrix non-zero ... = 1.1777
   Total space used in MD array .... = 443834
   Velocity initial condition analysis...
   Number of non-zero entries ...... = 4566
   Percentage of matrix non-zero ... = 1.2641
   Total space used in MD array .... = 446394
   Acceleration initial condition analysis...
   Number of equations ............. = 1174
   Number of non-zero entries ...... = 7299
   Percentage of matrix non-zero ... = 0.52957
   Total space used in MD array .... = 480482
   Generating the Jacobian matrix for the displacements and velocities.
   Total space used in MD array .... = 443858
   Generating the Jacobian matrix for the accelerations and forces.
   Total space used in MD array .... = 544436
   Generating the Jacobian matrix for the dynamics problem.
   Jacobian Matrix Statistics for a Dynamic Analysis
   Number of equations ............. = 1642
   Number of non-zero entries ...... = 18446
   Percentage of matrix non-zero ... = 0.68416
   Total space used in MD array .... = 863654
    Simulation         Time         Cumulative    Cumulative     Integrator
       Time            Step         Iterations    Steps Taken      Order
    ___________      ___________    __________    ___________    __________
    0.00000E+00      1.25000E-04           0              0           1
    1.25000E-04      1.25000E-04           4              1           1
---- WARNING ----
   The corrector has not converged after 6 attempts. No. of iterations = 10.
   At time 0.44125 and step 187 , ADAMS is adjusting solver and integrator
   parameters to attempt an integration restart.
   Total space used in MD array .... = 451204
   Total space used in MD array .... = 451692
   Total space used in MD array .... = 493970
   Total space used in MD array .... = 451716
   Total space used in MD array .... = 565782
   Total space used in MD array .... = 880612
    4.41250E-01      1.25000E-04         654            186           1
---- WARNING ----
   At integration time 0.44125 , the simulation is switching to a
   modified corrector algorithm.  The error norm will control integration
   variables only.
   At integration time 0.44125 , an Aitken formula over 5 previous
   iterations will be used to accelerate the convergence of the corrector.
    4.41250E-01      1.25000E-04         707            186           1
---- WARNING ----
   The corrector has not converged after 6 attempts. No. of iterations = 20.
---- ERROR ----
   The simulation stopped at time = 0.44125 .  ADAMS cannot solve
   the equations of motion.
   The greatest error in an equation is 3.62063E-02 in the
   equation for GFORCE try_fourpost.TR_Front_Tires_til_wheel_force .
   The greatest change in a variable is 1.26342E-13 in the
   variable for PART try_fourpost.TR_Front_Tires_whl_wheel .
   Try the following in this order:
       1.  Use the MAXIT argument on the EQUILIBRIUM, IC, KINEMATICS,
           or INTEGRATOR command to increase the maximum number of
           iterations.
       2.  Temporarily change the value of the PATTERN argument on the
           EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command to
           PATTERN = T.
       3.  Temporarily increase the value of the ERROR argument on the
           EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command at
           time = 0.44125 .
       4.  If one or more forces change rapidly or sharply near
           time = 0.44125, modify the force or forces.
   Enter Command:
   Enter Command:
   stop
   Terminating ADAMS/Car usersubs...
   ID = 1
      ADAMS/Solver execution terminated by subprogram A3TERM
   CPU time used = 13.891 seconds
One or more simulations were unsuccessful !
Please review the message file 'try_fourpost.msg' for details,
and verify the results with caution.
Simulation is complete.
麻烦各位大虾帮帮忙,不胜感激!~~~~~
GMT+8, 2025-4-22 16:31 , Processed in 0.021662 second(s), 13 queries , Gzip On, Redis On.
