查看: 22442|回复: 8
[已解决] proe5 m020 安装后问题
发表于 2010-5-19 15:10:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
proe 5 m020 安装后不能用
各位大侠,小弟在笔记本上安装PROE 5 M020 安装后运行 。后出现 warning;can't create a New Surface out of video memory
this program will exit
然后就不动了,要是点确定,就退出了,安装步骤都是正确的,请教高手
小弟的笔记本显卡是集成的
发表于 2010-5-19 16:20:19 | 只看该作者
PROE安装后要破解的,按下步骤:
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
1.修改环境变量。我的电脑---属性---高级---环境变量---新建---变量名:lang 值:chs。(chs就是简体中文的意思,以保证你的安装界面是简体中文) 2.Proe只所以稍微比其它软件难装一点,就是它license里的hostid要为你的mac号(用记事本打开ptc_li-4.0.dat。将里面的<00-11-D8-BB-5B-62> (注:这里是.DAT里面的ID)全部替换为你自己的网卡ID(dos下ipconfig/all),替换的具体操作为:单击记事本菜单栏上的“编辑”-“替换”,在“查找内容”里输入:<00-11-D8-BB-5B-62>(在“替换为”里输入你的网卡ID: XX-XX-XX-XX-XX-XX,然后点击 “全部替换”,保存后关闭)。
2、开始安装。需要安装中文版(建议进行设置,否则安装页面为乱码,破解后亦可能为乱码)请先把我的电脑属性高级下的环境变量中新建系统变量,变量名= lang 变量值=chs 或 =cht [简体/繁体],再进入安装程序,在选择语言时请勾选需要的语言,在继续安装直至完成!
3、双击“SETUP.EXE”开始安装.这里要是没反应的话不能直接安装的话,从压缩管理器里直接双击.EXE文件也可以. 下一步,接受许可证协议的条款和条件,下一步;不要安装PTC License Server,直接点Pro/ENGINEER进入下一界面,选择你要安装在什么位置,最好不要安装Pro/ENGINEER Help Files,因为这个帮助文件占很多空间且没什么用,继续下一步,单击“添加”-“锁定的许可证文件(服务器未运行)”-找到前面修改过的ptc_li- 4.0.dat(路径限英文,须将路径中的数字和其他符号去掉),下一步直至安装完Pro/ENGINEER 安装.
4、中间可能有个两个小细节 A当提示插入光盘2的时候 选择浏览直接选择CD2文件夹(注意不是打开文件) ,程序可自动读取光盘2 安装CD2 再用相同方法安装CD3。直到安装完成 ,安装过程中直接点下一歨即可。CD3的话一般是HELP文件,占很多空间.你要是装了请继续. 注意:如果出现正常安装完而无法启动的问题,请检查你的显卡是否为ATI显卡,若为ATI系列显卡则必须使用官方驱动,omega驱动不支持ProE等设计软件的显示。 5、安装完毕之后启动程序,发现界面为英文(已进行中文设置),而且license竟无效,点“OK”程序即关闭,须破解:把CRACK里面没有用的文件复制到proewildfire/i486-nt/obj里面,然后运行改文件,点击PATCH---是。选择文件,找到proewildfire/i486_nt/obj,这时你要选择文件类型,选择第二个类型.exe,然后找到XTOP.EXE--- -打开,弹出对话框,选择;是,还是找到XTOP.EXE,如此三次,一共需要生成5个新文件(但是也有一次就可以的,只要不出现选择是或否的对话框就可以了)。未进行中文设置破解后可能为乱码。
发表于 2010-5-19 17:10:13 | 只看该作者
out of video memory
是不是显存不足呀
发表于 2010-5-19 17:43:32 | 只看该作者
我倒 到处都看到装好不能用的问题!
我是hp cq40的笔记本 win7旗舰版32位系统 野火5从f000到m040每个版本都装过 无任何问题!
台式机是win7旗舰版64位 野火5也装过f000和m030两个64的版本 从未发现有问题 不知道大家是怎么装法的
发表于 2010-5-19 21:11:34 | 只看该作者
感谢各位的回复,尤其感谢三楼的朋友,确实是显存不足,我的是集成显卡只有16M,调到32M就没事了,谢谢各位
发表于 2010-9-28 21:11:34 | 只看该作者
我最近下了个M040,装了没什么问题
发表于 2010-11-29 10:14:28 | 只看该作者
听课填充!!!
发表于 2011-1-9 21:27:51 | 只看该作者
你们在那下载的,我找不到下载地址?我现在的PRO/E5.0有问题?
发表于 2011-6-23 14:56:04 | 只看该作者
我的m020mechanica用不了  求解
GMT+8, 2025-4-22 04:54 , Processed in 0.025410 second(s), 11 queries , Gzip On, Redis On.
