查看: 18114|回复: 2
[转贴] UG二次开发将part导出为iges文件
发表于 2010-5-31 11:01:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//full_path: path to save igs file
//part_name:current displayed part name
int Export_Part_to_IGES(CString full_path, CString part_name)
        char cmdfilename[MAX_FSPEC_SIZE+1];
        char cmdtext[256],trtool[256],trsour[256],trdes[256],trdef[256];
        FILE * filestream;
        char *UG_dir;
        UF_translate_variable("UGII_BASE_DIR", &UG_dir);
       strcpy(cmdfilename,full_path);
         strcat(cmdfilename,"temp.bat");
         filestream = fopen(cmdfilename,"w");
        strcpy(cmdtext,"@echo off\n");
         fprintf(filestream,"%s",cmdtext);
       strcpy(trtool,"\"");
         strcat(trtool,UG_dir);
        strcat(trtool,"\\iges\\iges.cmd\" ");
         strcpy(trsour,"\"");
        strcat(trsour,full_path);
        strcat(trsour,part_name);
         strcat(trsour,".prt\"  ");
       strcpy(trdes,"o=\"");
         strcat(trdes,full_path);
         strcat(trdes,part_name);
         strcat(trdes,".igs\"  ");
        strcpy(trdef,"d=\"");
        strcat(trdef,UG_dir);
        strcat(trdef,"\\iges\\igesexport.def\"");
       fprintf(filestream,"%s%s%s%s\n",trtool,trsour,trdes,trdef);         G
        fclose(filestream);
       SHELLEXECUTEINFO ShExecInfo;
         ShExecInfo.cbSize = sizeof( SHELLEXECUTEINFO );
         ShExecInfo.fMask = SEE_MASK_NOCLOSEPROCESS;
         ShExecInfo.hwnd = NULL;
        ShExecInfo.lpVerb = NULL;
        ShExecInfo.lpFile = cmdfilename;
        ShExecInfo.lpParameters = NULL;
        ShExecInfo.lpDirectory = NULL;
         ShExecInfo.nShow = SW_HIDE;
         ShExecInfo.hInstApp = NULL;
         ShellExecuteEx( &ShExecInfo );
        WaitForSingleObject( ShExecInfo.hProcess,INFINITE );
        return 0;
发表于 2010-6-12 15:05:04 | 只看该作者
学习了,这是外部模式做的吧
internal模式也可以导出
发表于 2011-2-15 03:25:29 | 只看该作者
internal 怎么做? 用 UF_CFI_spawn()? 3x
2# begtostudy
GMT+8, 2025-3-5 12:16 , Processed in 0.026750 second(s), 10 queries , Gzip On, Redis On.
