查看: 16743|回复: 4
MASTERCAM的快捷键
发表于 2003-7-4 10:49:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MasterCAM的快捷键
To: Press:
Set the construction depth
  (Z) Alt + 0
Set the main system color
  Alt + 1
Set the main system level
  Alt + 2
Set a mask level Alt + 3
Set the tool plane (Tplane) Alt + 4
Set the construction plane (Cplane) Alt + 5
Set the graphics view (Gview) Alt + 6
Use AutoSave Alt + A
Make the toolbar visible/invisible Alt + B
Run C-Hooks Alt + C
Set drafting global parameters (PM) Alt + D
Access the Hide function Alt + E
Select a new menu font Alt + F
Access the Selection Grid Parameters dialog box Alt + G
Access online help Alt + H
List open files Alt + I
Access Job Setup parameters Alt + J
Set line style and line width Alt + L
View memory allocations Alt + M
Edit named views Alt + N
Access the Operations Manager dialog box Alt + O
Make the prompt area visible/invisible Alt + P
Undo the last operation Alt + Q
Edit the last operation Alt + R
Toggle full-time shading on/off Alt + S
View Mastercam version number and SIM serial number Alt + V
Set the viewport configuration Alt + W
Access the Xform menu Alt + X
Set visible levels Alt + Z
Access the Create, Arc, Circle 2 points function Alt + ‘
Fit geometry to the screen Alt + F1
Unzoom by 0.8 Alt + F2
Toggle cursor tracking on/off Alt + F3
Exit Mastercam Alt + F4
Access the Delete function using window selection Alt + F5
Access the Blank function Alt + F7
Access the System Configuration dialog box Alt + F8
Draw axes for the current world view (center), the current Cplane (lower-left), and the current Tplane (lower-right) Alt + F9
List all functions that can be assigned special keys. You can access a function by double-clicking its name from the list. Alt + F10
Zoom F1
Unzoom F2
Repaint F3
Access the Analyze menu F4
Access the Delete menu F5
Access the File menu F6
Access the Modify menu F7
Access the Create menu F8
Display the origins (system, construction, and tool), if defined, and the properties of the current file F9
List all functions that can be assigned special keys. You can access a function by double-clicking its name from the list. F10
Zoom in Page Up
Zoom out Page Down
Interrupt the system Esc
Pan Arrow buttons
发表于 2012-6-1 09:10:00 | 只看该作者
这段时间,通过各部门同事的共同努力,终于“服装基因”收到了明显的效果!
而公司为了奖励服装基因店主,更是针对“活跃店主”进行奖励。每天对活跃店主的第1名都有现金奖励10元人民币,办公室还有同事打趣说下班回家后也要去当当店主。
来公司有这么些时间了,在学校的时候虽然有时候会很同学在一起搞些活动,但是第一次有这种成就感。我虽然没有出到什么力,但是大家一起共同努力,共同探讨进步是一种难能可贵的精神。
每天虽然很忙碌,但是日子过得特别的充实!由其是当取得一定效果的时候,那种开心是花钱也买不来的。
用一句什么话来鼓励自己呢?
加油,明天会更好~~~~~
发表于 2012-6-1 12:12:19 | 只看该作者
什么的东西啊
发表于 2012-6-1 14:36:04 | 只看该作者
XHG888 发表于 2012-6-1 12:12
什么的东西啊
英文,都不想看了
发表于 2012-6-17 10:25:35 | 只看该作者
{:soso_e100:}
GMT+8, 2025-4-22 16:56 , Processed in 0.024903 second(s), 11 queries , Gzip On, Redis On.
