查看: 18367|回复: 0
CAA创建参数后的删除问题
发表于 2010-6-25 15:25:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
添加参数代码大致如下:
 CATFrmEditor *_FrmEditor = CATFrmEditor::GetCurrentEditor();
  CATDocument *_Document = _FrmEditor -> GetDocument();
  CATInit *pInitOnDocument = NULL ;
  _Document->QueryInterface(IID_CATInit,(void **) &pInitOnDocument);
  CATIPrtContainer *pIPrtContOnDocument = NULL ;
  pIPrtContOnDocument = (CATIPrtContainer*)pInitOnDocument->GetRootContainer("CATIPrtContainer");
  CATICkeParmFactory *pCkeParFact = NULL;
  pIPrtContOnDocument -> QueryInterface(IID_CATICkeParmFactory, (void**) &pCkeParFact);
  CATICkeParm_var spParm = pCkeParFact->CreateLength ("paramLength",0);
  CATCkeGlobalFunctions::GetFunctionFactory()->AddToCurrentParameterSet(spParm);
我用此方法在一个新建的Part文件中添加后参数后在树上可以显示,但是尝试在CATIA删除却提示"You can delete only the new parameters that you have added to the part.
The parameters created for each feature can be deleted only by deleting the feature itself."
如果不通过程序直接在CATIA建的参数都可以删的,请高手指教CAA中有没有其他添加可删除的参数的方法或能删除以上参数的方法.
GMT+8, 2025-4-26 10:01 , Processed in 0.021827 second(s), 12 queries , Gzip On, Redis On.
