查看: 16360|回复: 2
[求助] UG API 双击CAM操作打开操作对话窗口
发表于 2010-7-9 10:17:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
双击CAM操作打开操作对话窗口,API有这个函数吗?
发表于 2010-7-13 14:46:38 | 只看该作者
有的
UF_UI_PARAM_edit_object (view source)
Defined in: uf_ui_param.h
Overview
This function displays the dialog for the object of the input "obj_tag".
The obj_tag has to be CAM object. The dialog that is displayed will be the
default dialog for the object. In the interactive session editing a CAM
object from the Operation Navigator causes the dialog of the object to be
brought up. Calling this function will have the same effect.
发表于 2010-7-13 14:47:10 | 只看该作者
是先获取操作的tag
GMT+8, 2025-4-22 15:40 , Processed in 0.020399 second(s), 11 queries , Gzip On, Redis On.
