查看: 19141|回复: 11
[求助] 招聘车载信息娱乐通讯主机单元机械设计
发表于 2010-7-13 16:05:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
借论坛宝地招聘机械工程师两名,主要方向为车载信息娱乐通讯主机单元机械设计,前装市场,大部分是双DIN的,干的活比较杂,CAD,CAE都要做,客户,工厂,供应商都要跑.公司为零部件外资上海研发中心.
职位要求:
The individuals are needed to design and implement mechanical system used in an automotive infotainment environment.
Main Responsibilities:
1. Participate in the design specification definition
2. Create and control technical document/files/drawings.
3. Design high quality mechanical architecture/parts within the system to specification, especially for vehicle head-unit.
4. Perform design analysis (tolerance analysis, vibration analysis, thermal analysis, etc.).
5. Create test plans and execute test per plan.
6. Support sourcing & production engineering, work with mechanical part supplier to secure product design release and safe launch.
7. Support quality control for problem investigations
8. Support production team in maintenance of line, including trouble shooting, root cause analysis & fix of issues found in production.
Key Competencies:
1. Bachelor Degree or above in engineering, more than 5 years experiences in related field
2. Sheet metal mechanical design knowledge, plastic part design and surface finishing process knowledge
3. Reliability validation (Environmental, EMI/EMC) experience for automotive environment.
4. Mechanical design & analysis experience especially in automotive head-unit section.
5. Use of popular M-CAD tools (Pro/E, CATIA, etc)
6. Mechanical related simulation skills (Vibration, Thermal, etc.)
7. Mechanical parts evaluation and testing experience
8. Analytical and problem solving skills
9. FMEA analysis skills is a plus
10.Good command of English
11.Team Work spirit .
Desired Skills:
1. Vehicle head-unit design experience.
发表于 2010-7-13 16:06:38 | 只看该作者
绝对是诚意招聘,因为HR找不到合适的,希望来论坛上看看有没有合适的兄弟.
关于大家比较关心的米的问题,10W/年保底,具体面试来谈,为提高机械行业薪资水平共同努力.
如有意向且符合要求的兄弟,请将个人简历发送给我kong_jun77@126.com,我会挑选部分(我本人也是ME)推荐给老大.如想多了解一些相关的信息,也欢迎发邮件给我,我一定会回复.
请大家多帮忙,实在是要找到合适的人才很不容易,如今愿意做技术的人少啊....
发表于 2010-7-13 16:08:42 | 只看该作者
帖子比较长,所以被截成两段了.
发表于 2010-7-15 15:46:52 | 只看该作者
哎,有兄弟有意向吗? 到底是米少还是做这个产品的人少?
发表于 2010-7-15 15:57:27 | 只看该作者
招聘机械工程师两名,主要方向为车载信息娱乐通讯主机单元机械设计,上海二手挖机,上海二手挖掘机前装市场,大部分是双DIN的,干的活比较杂,CAD,CAE都要做,客户,工厂,供应商都要跑.公司为零部件外资上海研发中心!
发表于 2010-7-16 10:16:49 | 只看该作者
帮顶!貌似不错的待遇。
发表于 2010-7-16 10:25:36 | 只看该作者
待遇在业内还可以的,弹性工作制,基本不用加班,在上海市中心.
希望有合适的人选可以帮忙推荐一下啊.
发表于 2010-7-16 19:23:54 | 只看该作者
请问楼主,上海市中心消费水平应该很高,住宿能提供不?上海这里公司是专设计,还是集设计、五金塑胶开模及产品组装一体的呢?产品是否覆盖日系、韩系、美系车,还是专给某一汽车厂商配套供货呢?
发表于 2010-7-16 22:08:52 | 只看该作者
回楼上的兄弟,上海市中心交通非常便利,不提供住宿(上海外企基本没有提供住宿的),公司有交通补贴,在市中心的消费主要就是中午的午餐费用,一般10~20元,公司有饭贴,交通补贴和饭贴都是有剩余的,当然你也可以看成工资组成的一部分。因为交通便利,可以租稍远但是便宜一些的房子,如果就在公司旁边租,通常1000元可以租到一个房间。
公司是500强的研发中心,专门做新产品设计,开模是外发,组装工厂也在外地。产品覆盖 德,日,法,美,韩系国内各大整车厂,一供。车载信息娱乐通讯主机是今年新开的产品线,只做中高端市场。
楼上的兄弟可能是南方一带的,如果想到上海发展,我们很欢迎,同时也希望外地过来的兄弟要考虑慎重,做好长远发展的打算。
发表于 2010-7-20 19:00:36 | 只看该作者
请问quentin_ko,我英语一般般,没怎么用过;其它没什么,做过单锭、双锭、内部放碟片的机芯等传动机构,像华阳7寸翻屏机,4寸下滑机。不知合条件否?
工厂在哪里?供应商是否是供应工厂零部件的厂家?客户是否是指整车厂?
GMT+8, 2025-4-19 02:50 , Processed in 0.027365 second(s), 12 queries , Gzip On, Redis On.
