查看: 16938|回复: 7
[原创] 大家谁知道查询尺寸个数是用的哪个函数啊?知道的说下,谢谢啦
发表于 2010-7-14 15:47:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2010-7-14 19:31:00 | 只看该作者
用数据库循环,用这个类型筛选
#define UF_dimension_type                        26
发表于 2010-7-15 09:41:59 | 只看该作者
2# zjs
发表于 2010-7-15 09:45:17 | 只看该作者
谢谢zjs,我是刚学ug二次开发的,如果你有类似方面的例子给上传几个让我们这些新手学习学习,谢谢了,如果没有的话也没关系,我再找找。 2# zjs
发表于 2010-7-22 00:35:48 | 只看该作者
这是report obj information 的,可以参考一下
static void report_object_info(char *what, tag_t object)
    int
        status,
        subtype,
        type;
    tag_t
        owner;
    char
        name[UF_OBJ_NAME_LEN + 1],
        msg[133];
    UF_OBJ_disp_props_t
        disp_props;
    UF_CALL(UF_UI_open_listing_window());
    if (object != NULL_TAG)
        UF_CALL(UF_OBJ_ask_type_and_subtype(object, &type, &subtype));
        sprintf(msg, "%s = %d, type = %d, subtype = %d, ", what, object, type,
            subtype);
        if (UF_OBJ_is_object_a_promotion(object)) strcat(msg, "promotion, ");
        if (UF_ASSEM_is_occurrence(object)) strcat(msg, "occurrence, ");
        UF_CALL(UF_UI_write_listing_window(msg));
        if (!UF_CALL(UF_OBJ_ask_owning_part(object, &owner)))
            sprintf(msg, "owned by %d, ", owner);
        if (!uc6409(object, &status, name) && (status == 1))
            sprintf(msg, "view dependent in %s, ", name);
        if (!UF_OBJ_ask_name(object, name))
            sprintf(msg, "named %s, ", name);
        status = UF_OBJ_ask_status(object);
        sprintf(msg, "status %d\n", status);
        if (UF_OBJ_is_type_displayable(type))
            UF_CALL(UF_OBJ_ask_display_properties(object, &disp_props));
            sprintf(msg, "  layer = %d, color = %d, blank = %d, width = %d, "
                "font = %d, highlight = %d\n", disp_props.layer,
                disp_props.color, disp_props.blank_status,
                disp_props.line_width, disp_props.font,
                disp_props.highlight_status);
    else
        sprintf(msg, "%s = %d (NULL_TAG)\n", what, object);
发表于 2010-7-24 08:39:00 | 只看该作者
UfS.Modl.AskBoundingBoxExact(object_tag, csys_tag, min_corner, direction, distances)创建最大包体返回最大外形尺寸
发表于 2010-8-12 10:09:49 | 只看该作者
谢谢 5# zjs
发表于 2012-6-12 16:09:33 | 只看该作者
学习了,谢谢
GMT+8, 2025-2-23 03:41 , Processed in 0.034922 second(s), 10 queries , Gzip On, Redis On.
