查看: 16415|回复: 12
这个问题是怎么回事呀,大家帮帮我呀!
发表于 2003-7-5 16:46:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的后置处理设置如下:
发表于 2003-7-5 16:49:49 | 只看该作者
发表于 2003-7-5 16:50:13 | 只看该作者
发表于 2003-7-5 16:51:17 | 只看该作者
发表于 2003-7-5 16:51:42 | 只看该作者
发表于 2003-7-5 16:55:06 | 只看该作者
我用这个后置处理处理如下NCL文件:
$$*          Pro/CLfile  Version Wildfire - 2003051
$$-> MFGNO / MFG0001
PARTNO / MFG0001
$$-> FEATNO / 22
MACHIN / UNCX01, 5
$$-> CUTCOM_GEOMETRY_TYPE / OUTPUT_ON_CENTER
UNITS / MM
LOADTL / 1
$$-> CUTTER / 20.000000
$$-> CSYS / 1.0000000000, 0.0000000000, 0.0000000000, 0.0000000000,  $
            0.0000000000, 1.0000000000, 0.0000000000, 0.0000000000,  $
            0.0000000000, 0.0000000000, 1.0000000000, 0.0000000000
MULTAX / ON
SPINDL / RPM, 1800.000000,  CLW
COOLNT / ON
RAPID
GOTO / -35.4655581463, 0.0000000000, 80.0000000000,  $
0.0599152609, 0.0000000000, 0.9982034670
RAPID
GOTO / -35.4655581463, 0.0000000000, 54.4721359550,  $
FEDRAT / 1000.000000,  MMPM
GOTO / -36.0647107550, 0.0000000000, 44.4901012851,  $
GOTO / -36.0313578056, 1.5331614448, 44.4900407776,  $
0.0598659040, -0.0026037221, 0.9982030325
GOTO / -35.9315570355, 3.0669148511, 44.4899004960,  $
0.0597149892, -0.0051804608, 0.9982020251
GOTO / -35.7657617410, 4.5979456306, 44.4897337075,  $
0.0594588220, -0.0077303084, 0.9982008269
GOTO / -35.5345268495, 6.1228323627, 44.4895821179,  $
0.0590945350, -0.0102528011, 0.9981997375
GOTO / -35.2385023172, 7.6381641145, 44.4894758243,  $
0.0586201052, -0.0127472599, 0.9981989735
GOTO / -34.8783913983, 9.1406840503, 44.4894333450,  $
0.0580342894, -0.0152131626, 0.9981986681
GOTO / -34.4549454008, 10.6271944401, 44.4894616888,  $
0.0573365973, -0.0176501231, 0.9981988718
GOTO / -33.9690272803, 12.0943423043, 44.4895563428,  $
0.0565273695, -0.0200576755, 0.9981995523
GOTO / -33.4218445471, 13.5381419321, 44.4897011122,  $
0.0556081359, -0.0224346157, 0.9982005927
GOTO / -32.8148053120, 14.9546608239, 44.4898680648,  $
0.0545813364, -0.0247802317, 0.9982017921
GOTO / -32.1492535067, 16.3405653849, 44.4900176600,  $
0.0534498016, -0.0270953122, 0.9982028665
GOTO / -31.4261678657, 17.6934212187, 44.4900988196,  $
0.0522161381, -0.0293827969, 0.9982034493
GOTO / -30.6453543209, 19.0128320555, 44.4900587819,  $
0.0508903462, -0.0316325845, 0.9982031618
GOTO / -29.8055523243, 20.3010106401, 44.4899214506,  $
0.0494896401, -0.0338111248, 0.9982021756
GOTO / -28.9089861081, 21.5548616767, 44.4897449549,  $
0.0480117536, -0.0359140552, 0.9982009077
GOTO / -27.9583214255, 22.7710072572, 44.4895758431,  $
0.0464547752, -0.0379384751, 0.9981996924
GOTO / -26.9563446212, 23.9462834539, 44.4894484434,  $
0.0448177540, -0.0398819668, 0.9981987766
GOTO / -25.9050820440, 25.0786134777, 44.4893848325,  $
0.0430992124, -0.0417441409, 0.9981983193
GOTO / -24.8061788927, 26.1662617290, 44.4893952318,  $
0.0412976724, -0.0435254913, 0.9981983940
GOTO / -23.6610202471, 27.2075839460, 44.4894782016,  $
0.0394117297, -0.0452271026, 0.9981989906
生成的NC程序:
N1$
N2T1$
N3M6$
N4S1800M3$
N5G0Z77.731M8$
N6X-40.195Y0.A0.B3.435$
N7G94$
N8G93$
N9G0X-38.666Y0.$
N10Z52.249$
N11G94$
N12G1X-38.666Y0.Z42.249F1000.$
N13G93$
N14G1X-38.63Y1.533Z42.253A-.149B3.432F652.16$
N15G1X-38.524Y3.067Z42.265A-.297B3.424F650.57$
N16G1X-38.348Y4.598Z42.285A-.443B3.409F649.33$
N17G1X-38.102Y6.123Z42.312A-.587B3.388F648.33$
N18G1X-37.786Y7.638Z42.347A-.73B3.361F647.73$
N19G1X-37.402Y9.141Z42.39A-.872B3.327F647.14$
N20G1X-36.95Y10.627Z42.441A-1.011B3.287F647.15$
N21G1X-36.43Y12.094Z42.498A-1.149B3.241F647.17$
N22G1X-35.845Y13.538Z42.562A-1.286B3.189F647.71$
N23G1X-35.195Y14.955Z42.632A-1.42B3.13F648.74$
N24G1X-34.482Y16.341Z42.707A-1.553B3.065F650.26$
N25G1X-33.707Y17.693Z42.788A-1.684B2.994F652.05$
N26G1X-32.871Y19.013Z42.872A-1.813B2.919F652.15$
N27G1X-31.972Y20.301Z42.96A-1.938B2.838F650.35$
N28G1X-31.013Y21.555Z43.05A-2.058B2.754F648.64$
N29G1X-29.996Y22.771Z43.142A-2.174B2.665F647.65$
发表于 2003-7-5 17:02:09 | 只看该作者
按我的理解NC中的加红的数据应该是:
先忽略格式只讨论数据的值:
N1G1X-35.466Y0.Z80.A0.B3.435
N2Z54.472
N3X-36.065Z44.49
N4X-36.031Y1.649Z44.486A.149B3.432
N5X-35.932Y3.298Z44.473A.297B3.423
N6X-35.766Y4.942Z44.453A.444B3.409
N7X-35.535Y6.579Z44.424A.588B3.388
N8X-35.239Y8.206Z44.388A.732B3.361
因为我在上面图2中的Pivot distance参数设置为0,那么在A=0的情况下,B值不管变化是多少,X、Y、Z的值应该是和NCL数据一直。
但为什么我的后置处理生成的不同呢?
斑竹?这个差值是怎么产生的?谢谢
发表于 2003-7-5 17:17:58 | 只看该作者
我的机床是这种类型:
发表于 2003-7-5 18:54:39 | 只看该作者
五轴的东东,我不懂,期待台湾的高手出手......
发表于 2003-7-5 20:57:09 | 只看该作者
大哥们救我呀,我真的解决不了这个问题了
GMT+8, 2025-4-27 14:45 , Processed in 0.042072 second(s), 13 queries , Gzip On, Redis On.
