查看: 16764|回复: 4
[求助] C#开发UG时出错了(不解)
发表于 2010-9-11 18:49:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用C#做的一个EXE程序,重复调用的时候出错了:
不解啊!
一下是源代码:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using NXOpen;
using NXOpen.Utilities;
using NXOpen.UF;
using NXOpenUI;
namespace test1
    public partial class Form毛坯创建工具 : Form
        public Form毛坯创建工具()
            InitializeComponent();
        private string x;
        private string y;
        private string z;
        private void button创建_Click(object sender, EventArgs e)
            Session thesession = Session.GetSession();
            try
                Part thepart = thesession.Parts.Work;
                NXOpen.Features.Feature block = null;
                NXOpen.Features.BlockFeatureBuilder thebuilder = thepart.Features.CreateBlockFeatureBuilder(block);
                x = textBoxX.Text;
                double x1 = Convert.ToDouble(x);
                y = textBoxY.Text;
                double y1 = Convert.ToDouble(y);
                z = textBoxZ.Text;
                double z1 = Convert.ToDouble(z);
                NXOpen.Point3d basepoint = new Point3d(x1, y1, z1);
                thebuilder.SetOriginAndLengths(basepoint ,textBoxΔX.Text ,textBoxΔY .Text ,textBoxΔZ.Text);
                thebuilder.Commit();
                MessageBox.Show("毛坯建造完毕!");
            catch (NXException ex)
                MessageBox.Show("ERROR!");
        private void button退出_Click(object sender, EventArgs e)
            Close();
请高手多多赐教!
发表于 2010-9-11 18:55:41 | 只看该作者
我顶!~~~~~~~~~~~~~
发表于 2010-9-18 15:13:59 | 只看该作者
我自己再顶!~
发表于 2010-9-21 00:11:38 | 只看该作者
这是外部模式,在UG内不能调用吧
发表于 2010-11-26 18:44:29 | 只看该作者
你说的对,谢谢你!
GMT+8, 2025-7-11 09:22 , Processed in 0.029144 second(s), 11 queries , Gzip On, Redis On.
