查看: 15537|回复: 0
[求助] 有谁可以教我用durability analysis ?
发表于 2010-9-14 15:23:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
In stress safetyfactor,when should i use ultimate str or yield str ?
In fatigue safetyfactor,when should i use infinite life or cycles to failure?
In fatigue life, what is the difference between each option under fatigue criterion ?
GMT+8, 2025-2-7 06:05 , Processed in 0.028714 second(s), 13 queries , Gzip On, Redis On.
