查看: 18447|回复: 6
proe转cad
发表于 2010-9-15 19:57:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教大侠们:+ v1 Z* N! p! }
在proe转为CAD后,会自动生成
1 R5 U2 b- O1 g+ t9 d0
; z: ]9 f" y( _9 g: t* NDEFAULT_1
4 K4 t1 F! S" x# YDEFAULT_2
' g* k+ h) ~5 _- S/ D9 SDEFAULT_3- k7 d3 Q' c: i' A6 {
怎么把这些图层去掉。
; R9 t  O$ a  ^
6 t$ ]! `" ]' U& F另:; `$ ]" f4 U0 a" I7 Q; i. s- z, X+ S
我已经设置了如下的配置文件4 h6 t% x9 B+ y8 f
DEFAULT_15 m! B6 j$ Y/ o4 u
DEFAULT_2) }" }7 @, E/ i$ o
DEFAULT_3
2 [9 Q* h1 N5 O4 P输出的层还是' W; X" F: K- z4 C  U: {+ e  G
DEFAULT_1
  z" m- N0 T4 y" vDEFAULT_2
; r7 c2 U9 j" R' j9 vDEFAULT_3" V2 p+ p& _: h; z8 ^0 H
" c2 p+ j0 V1 ^. [% m- |8 a
4 p+ _# M3 ?2 B! T; X5 v
dxf_export.pro
/ v6 d. C0 @$ y9 L, z2 S6 Zmap_color Centerline_COLOR   6
6 M2 ~* l9 x% v; Omap_color LETTER_COLOR        1  + \$ w& v3 {# z4 |+ U+ N
map_color GEOMETRY_COLOR      7
! F3 J* v" `  y& f6 B) Cmap_color sheetmetal_COLOR    7
4 s; `4 @2 w; e9 d. ~+ Y: e( x1 J  Qmap_color SECTION_COLOR       4! I# U+ A: |7 [/ Y; [9 h
map_color Leader_COLOR       3
  Z  o3 ?( e% I1 ^3 F: }6 P
% A, t- h" C! x& j+ ?( A+ r0 }- ~map_line_style CTRLFONT CENTER( H1 g1 q1 l8 E2 X( G: n5 y
8 I- }7 J' V+ G7 ?0 g% R2 t; Xmap_layer Dxf_Axis               _axis; U7 l2 p! I/ [) f7 O3 p  Y( u5 O
map_layer Dxf_Continuous_Line    _solid1 y6 M8 ~- S8 L# a+ q5 [
map_layer Dxf_Hidden_Line        _hidden
9 E# ~1 f; |  r/ ~6 Z: rmap_layer Dxf_Dimension          _dim( b7 H/ |2 f2 E' `% k$ r) Y
map_layer Dxf_Text               _text
& w! x9 ]' [5 }+ c; m: i0 @$ A8 T' bmap_layer Dxf_Hatching           _section/ A( G" q) Z0 y6 a0 w# p) i
map_layer Dxf_Table              _table) F4 y( W+ H. Y0 Q) C' O7 z
map_layer Dxf_Balloon            _balloon% P0 e; W# b) k5 Z4 ]; R$ O
map_layer Dxf_Format             _format% N+ ]9 P- i) {' M  T
4 l0 [. g! W% V2 Y5 ~4 f
map_layer 0                       solid
# N) F1 C& f1 |0 e, K( omap_layer 01___PRT_ALL_DTM_PLN    solid         % _! \/ A' n+ m1 m0 u9 {
map_layer 01___PRT_DEF_DTM_PLN    solid
* k% h- c) ^2 d; R9 Y+ ymap_layer 02___PRT_ALL_AXES       solid         ' B# j1 [( [* n. {# Z! m
map_layer 03___PRT_ALL_CURVES     solid
) u9 v; _+ M2 v7 Z' Jmap_layer 04___PRT_ALL_DTM_PNT    solid         ! k! v+ q' X1 d; S- [& G
map_layer 05___PRT_ALL_DTM_CSYS   solid         . `4 `" A5 K+ u
map_layer 05___PRT_DEF_DTM_CSYS   solid         ! i( p  I1 |3 R% A; L
map_layer 06___PRT_ALL_SURFS      solid
" D$ N8 h% V" B2 v3 x7 r2 K0 B4 Rmap_layer DEFAULT_1               solid         , e$ u& T6 a7 u  q% u0 v  o& \
map_layer DEFAULT_2               solid
: v; h: k3 v) H- y6 t" y+ _map_layer DEFAULT_3               solid
发表于 2010-9-15 19:58:25 | 只看该作者
发表于 2010-9-16 16:13:13 | 只看该作者
这个问题一般在cad里面处理了,没用的图素就删除或者移到别的层,然后purge掉没用层,还没研究proe里面的设置。
发表于 2010-9-21 16:19:12 | 只看该作者
在PROE里设置层,转到CAD里后,把层关掉
发表于 2010-9-29 01:11:49 | 只看该作者
这倒是一个不错的做法
发表于 2010-10-7 19:08:17 | 只看该作者
好像可以啊
发表于 2010-11-4 12:26:34 | 只看该作者
路过学习..
GMT+8, 2025-4-8 22:22 , Processed in 0.024550 second(s), 12 queries , Gzip On, Redis On.
