查看: 16603|回复: 4
UG按照字高字宽写一行字的程序,请高手找毛病
发表于 2003-7-12 00:25:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我编了一个程序,首先用UF_DRF_set_lettering_preferences设定字体参数,之后用uc5540()在图纸的某一位置写出一行文字。
写文字部分没有问题,但是设定字体参数部分有毛病,请高手指教。万分感谢!
UF_DRF_lettering_preferences_p_t  lettering_preferences1;
UF_DRF_align_position_t align_position;
UF_DRF_text_just_t horiz_text_just;
double gdt_frame_height_factor;
double angle;
UF_DRF_lettering_t dimension_text1;
UF_DRF_lettering_t appended_text1;
UF_DRF_lettering_t tolerance_text1;
UF_DRF_lettering_t general_text1;
int lines_of_text;
char  text_string[1][133];
double origin_3d[3];
int orientation;
tag_t  text_tag;
//下面是用set_lettering_preferences设置字体参数
align_position=1;
horiz_text_just=1;
dimension_text1.size=3.5;
dimension_text1.character_space_factor=0.8;
dimension_text1.aspect_ratio=1.0;
dimension_text1.line_space_factor=1.0;
dimension_text1.cfw.color=3;
dimension_text1.cfw.font=3;
dimension_text1.cfw.width=3;
appended_text1.size=3.5;
appended_text1.character_space_factor=0.8;
appended_text1.aspect_ratio=1.0;
appended_text1.line_space_factor=1.0;
appended_text1.cfw.color=3;
appended_text1.cfw.font=3;
appended_text1.cfw.width=3;
tolerance_text1.size=3.5;
tolerance_text1.character_space_factor=0.8;
tolerance_text1.aspect_ratio=1.0;
tolerance_text1.cfw.color=3;
tolerance_text1.cfw.font=3;
tolerance_text1.cfw.width=3;
general_text1.size=3.5;
general_text1.character_space_factor=0.8;
general_text1.aspect_ratio=1.0;
general_text1.line_space_factor=1.0;
general_text1.cfw.color=3;
general_text1.cfw.font=3;
general_text1.cfw.width=3;
//红字处估计有问题
lettering_preferences1->align_position=align_position;
lettering_preferences1->horiz_text_just=horiz_text_just;
lettering_preferences1->gdt_frame_height_factor=10.0;
lettering_preferences1->angle=1.0;
lettering_preferences1->dimension_text=dimension_text1;
lettering_preferences1->appended_text=appended_text1;
lettering_preferences1->tolerance_text=tolerance_text1;
lettering_preferences1->general_text=general_text1;
UF_DRF_set_lettering_preferences([$lettering_preferences1)]
/* 下面是写1行字 */
lines_of_text=1;
origin_3d[0]=100.0;
origin_3d[1]=115.0;
origin_3d[2]=0.0;
orientation=0;
strcpy(text_string[0], "<F15>这是一个标注This is a LABEL.<F>");
uc5540(lines_of_text,text_string,origin_3d,[$text_tag)]
发表于 2003-7-19 20:33:53 | 只看该作者
兄弟,你用这个函数试试:UF_DRF_set_preferences( mpi_array, mpr_array,rad_symbol, dia_symbol)。它比单独设单个属性要方便。
发表于 2003-8-4 22:06:42 | 只看该作者
谢谢liberty兄。您的方法很好使,我已经调试成功了。
发表于 2003-8-8 10:57:41 | 只看该作者
楼上兄弟,请问你在如何在API中生成剖视图的?能否给个例子?谢谢!
发表于 2003-8-9 02:22:51 | 只看该作者
抱歉,小弟没有整过剖视图的程序。
GMT+8, 2025-4-20 05:53 , Processed in 0.024963 second(s), 12 queries , Gzip On, Redis On.
