查看: 19523|回复: 5
【讨论】CIMATRON it最新版本是不是13.1,有何新功能?
发表于 2003-7-13 10:17:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Cimatron it最新版本是不是13.1,有何新功能?在13的基础上有什么功能增加,各位说一说??
发表于 2003-7-13 13:56:59 | 只看该作者
translating a complex part design into a finished tool requires
an integrated solution -from data interface, through design
through manufacturing, to nc machining. from data-to-steel.
cimatron's software automates every stage of the tooling process.
designed for mold, tool and die makers, cimatron's cad/cam
tooling solution includes reliable data translation, hybrid
design-for-manufacturing capabilities and leading edge nc
technology. numerical control (nc) fully-integrated nc capabilities
provide all the technologies required to machine any complex part
patch and mend solid and surface models within the cam environment.
modeling provides a hybrid environment that enables the user to
incorporate surface and solid models into a single design sophisticated
sculptured surface tools make complex geometric shapes easy to define,
modify, manipulate and analyze assembly operations are performed on
solids within a special assembly environment wireframe tools support
complex surfaces and offer advanced sketcher capabilities, 3d spline
and intersection curve innovative quick technology contains unique
analysis and design capabilities mold base design automates mold-housing
design from industry standard catalogs or from user-defined libraries
of plates and components.
发表于 2003-7-13 21:11:11 | 只看该作者
麻烦哪位老兄能翻译一下吗???
发表于 2003-7-14 11:17:12 | 只看该作者
从数据接口转化为设计实体成为完美的工具需要和综合的解决方案,通过设计,通过制造,到NC加工。从数据到铁。cimatron软件使加工过程的每一个阶段自动化,模具设计,冲模使用工具,cimatron cad/cam的加工解决方案包括可靠的数据转化。太长了,后面的你们自己看吧
发表于 2003-7-21 16:38:02 | 只看该作者
The latest version of IT is 13.1 (pass 13.10.00.7)
Not much new from 12 to 13, but there are some bug fixes. This will also be the last release of the IT product, as the E product is now mature enought to stand on it's own. Copies have already shipped to US customers who are up on their maintenance, and have recently begun shipping to Canadian customers who are up on their maintenance. If you have not received your copy of IT13, please contact your salesman.
Tech Support Team
Cimatron Technologies
*****1-877-596-9700******
support@cimatrontech.com
www.cimatrontech.com
13。1是终结版,以后不出了伤心
发表于 2003-7-21 16:54:56 | 只看该作者
No, the latest version of IT is 13.1 (pass 13.10.00.13)
GMT+8, 2025-4-22 05:08 , Processed in 0.023562 second(s), 11 queries , Gzip On, Redis On.
