查看: 16829|回复: 0
[转贴] 分享一下,如何通过云来优化你的inventor设计作品。
发表于 2010-11-2 12:06:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  OVERVIEW
  The Inventor Optimization Technology Preview allows designers and engineers that use Autodesk Inventor to optimize their designs. It is a simple, web-based simulation tool to help an engineer minimize weight and cost while improving product safety.
  The Technology Preview offers Inventor users the ability to:
  Optimize Designs with Ease - An intuitive interface allows for quick and easy simulation set-up so any Inventor user can reduce weight and material used while improving product quality and safety.
  Work in Parallel - While the software is performing multiple simulations "behind the scenes" in the cloud, the designer or engineer can continue to do other work on his or her desktop. When the design optimization is complete, the technology preview’s job monitor automatically notifies the user through multiple communication channels.
  Tap into Unrivaled Performance - Offloading simulation to the cloud helps unleash the true power of simulation by enabling users to simulate many different design configurations in parallel, to access sufficient memory and the overall capacity required to perform simulations in less time.
  Enhancements in this release include:
  The compression algorithm for communicating data with the cloud now uses fewer resources.
  The animate feature is faster and consumes less memory.
  Mobile users can shutdown Inventor or even the machine after starting an optimization. Once the optimization is complete, just open the document, enter the optimization environment, and the results will be waiting for you.
GMT+8, 2025-4-30 05:15 , Processed in 0.021739 second(s), 11 queries , Gzip On, Redis On.
