查看: 15709|回复: 8
wild fire问题求助!
发表于 2003-7-16 09:46:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
为什么导角时这个选项是灰的?望高手赐教,谢谢!
发表于 2003-7-16 10:16:34 | 只看该作者
up!
发表于 2003-7-16 11:13:56 | 只看该作者
As you work with rounds, you may encounter a situation when more than one possible placement location exists for the current round set. This can happen when two surfaces intersect in multiple, distinct locations. If this situation occurs, placement ambiguity results in which the placement of the round pieces is unclear due to the selected references and part geometry.
发表于 2003-7-16 11:14:42 | 只看该作者
Pro/ENGINEER enables you to easily address placement ambiguity using two methods. The table below illustrates the two types of placement ambiguity and the methods used to address them:
发表于 2003-7-16 14:02:29 | 只看该作者
啊,看不懂,不过还是谢谢!
发表于 2003-7-16 15:22:17 | 只看该作者
发表于 2003-7-16 15:23:44 | 只看该作者
示例(av)
发表于 2003-7-16 15:30:05 | 只看该作者
简单地说:就是当导角有多解的时候,pro/e允许你进行人为的选择即:模糊
发表于 2003-7-16 15:46:13 | 只看该作者
非常感谢!
GMT+8, 2025-4-8 11:00 , Processed in 0.023392 second(s), 13 queries , Gzip On, Redis On.
