当然也可以用一种简便的方法来处理这个问题。类似于2D Axisymmetric plain strain.
只用了一个单元, 这种方法比上面那种3D的要快,结果两者相似。
将分析结果贴出来。
Pro/MECHANICA STRUCTURE Version 24.8(818)
Summary for Design Study "Analysis1"
Fri Jul 18, 2003 15:44:53
Run Settings
Memory allocation for block solver: 128.0
Checking the model before creating elements...
These checks take into account the fact that AutoGEM will
automatically create elements in volumes with material
properties, on surfaces with shell properties, and on curves
with beam section properties.
Generate elements automatically.
Checking the model after creating elements...
No errors were found in the model.
Pro/MECHANICA STRUCTURE Model Summary
  rincipal System of Units: millimeter Newton Second (mmNs)
Length: mm
Force: N
Time: sec
Temperature: C
Model Type: 2D Axisymmetric
Edges: 4
Faces: 1
Springs: 0
Masses: 0
2D Shells: 0
2D Solids: 1
Elements: 1
Standard Design Study
Static Analysis "Analysis1":
Convergence Method: Multiple-Pass Adaptive
  lotting Grid: 4
Convergence Loop Log: (15:44:54)
>> Pass 1 <<
Calculating Element Equations (15:44:54)
Total Number of Equations: 4
Maximum Edge Order: 1
Solving Equations (15:44:54)
  ost-Processing Solution (15:44:54)
Calculating Disp and Stress Results (15:44:54)
Checking Convergence (15:44:54)
Elements Not Converged: 1
Edges Not Converged: 4
Local Disp/Energy Index: 100.0%
Global RMS Stress Index: 100.0%
Resource Check (15:44:54)
Elapsed Time (sec): 1.65
CPU Time (sec): 1.40
Memory Usage (kb): 158692
Wrk Dir Dsk Usage (kb): 0
>> Pass 2 <<
Total Number of Equations: 10
Maximum Edge Order: 2
Edges Not Converged: 3
Local Disp/Energy Index: 28.0%
Global RMS Stress Index: 48.2%
Resource Check (15:44:55)
Elapsed Time (sec): 1.76
CPU Time (sec): 1.51
Memory Usage (kb): 159780
>> Pass 3 <<
Calculating Element Equations (15:44:55)
Total Number of Equations: 16
Maximum Edge Order: 3
Solving Equations (15:44:55)
  ost-Processing Solution (15:44:55)
Calculating Disp and Stress Results (15:44:55)
Checking Convergence (15:44:55)
Elements Not Converged: 0
Edges Not Converged: 2
Local Disp/Energy Index: 8.1%
Global RMS Stress Index: 23.5%
Elapsed Time (sec): 1.87
CPU Time (sec): 1.61
>> Pass 4 <<
Total Number of Equations: 22
Maximum Edge Order: 4
Post-Processing Solution (15:44:55)
Edges Not Converged: 0
Local Disp/Energy Index: 5.6%
Global RMS Stress Index: 24.5%
Elapsed Time (sec): 1.97
CPU Time (sec): 1.72
>> Pass 5 <<
Total Number of Equations: 32
Maximum Edge Order: 5
Local Disp/Energy Index: 9.8%
Global RMS Stress Index: 33.9%
Elapsed Time (sec): 2.17
CPU Time (sec): 1.83
>> Pass 6 <<
Total Number of Equations: 42
Maximum Edge Order: 6
Local Disp/Energy Index: 5.1%
Global RMS Stress Index: 14.5%
Elapsed Time (sec): 2.28
CPU Time (sec): 1.94
>> Pass 7 <<
Total Number of Equations: 56
Maximum Edge Order: 7
Local Disp/Energy Index: 2.3%
Global RMS Stress Index: 7.1%
Stress error estimates are not available
because all external element edges lie
in regions that are constrained or where
the stress is potentially singular.
Elapsed Time (sec): 2.41
CPU Time (sec): 2.07
The analysis converged to within 8% on
edge displacement, element strain energy,
and global RMS stress.
Total Mass of Model: 2.704845e-04
Total Cost of Model: 0.000000e+00
Mass Moments of Inertia about WCS Origin:
Ixx: 4.21505e-01
Ixy: 0.00000e+00 Iyy: 8.24978e-01
Ixz: 0.00000e+00 Iyz: 0.00000e+00 Izz: 4.21505e-01
Principal MMOI and Principal Axes Relative to WCS Origin:
Max Prin Mid Prin Min Prin
8.24978e-01 4.21505e-01 4.21505e-01
WCS X: 0.00000e+00 0.00000e+00 1.00000e+00
WCS Y: 1.00000e+00 0.00000e+00 0.00000e+00
WCS Z: 0.00000e+00 1.00000e+00 0.00000e+00
Center of Mass Location Relative to WCS Origin:
( 0.00000e+00, 5.00000e+00, 0.00000e+00)
Mass Moments of Inertia about the Center of Mass:
Ixx: 4.14743e-01
Ixz: 0.00000e+00 Iyz: 0.00000e+00 Izz: 4.14743e-01
Principal MMOI and Principal Axes Relative to COM:
8.24978e-01 4.14743e-01 4.14743e-01
Constraint Set: ConstraintSet1
Load Set: LoadSet1
Resultant Load on Model:
in global Y direction: -1.103655e-12
Measures:
Name Value Convergence
max_disp_mag: 1.515027e-04 0.7%
max_disp_x: 1.426293e-04 0.9%
max_disp_y: 5.108766e-05 0.3%
max_disp_z: 0.000000e+00 0.0%
max_prin_mag: 6.092675e+00 10.2%
max_rot_mag: 0.000000e+00 0.0%
max_rot_x: 0.000000e+00 0.0%
max_rot_y: 0.000000e+00 0.0%
max_rot_z: 0.000000e+00 0.0%
max_stress_prin: 6.092675e+00 10.2%
max_stress_vm: 4.729459e+00 9.9%
max_stress_xx: 2.090094e+00 10.4%
max_stress_xy: 2.206304e+00 9.6%
max_stress_xz: 0.000000e+00 0.0%
max_stress_yy: 4.876515e+00 10.4%
max_stress_yz: 0.000000e+00 0.0%
max_stress_zz: 2.089983e+00 10.4%
min_stress_prin: -4.124980e+00 7.0%
strain_energy: 1.274590e-01 0.8%
Analysis "Analysis1" Completed (15:44:55)
Memory and Disk Usage:
Machine Type: Windows NT/x86
RAM Allocation for Solver (megabytes): 128.0
Total Elapsed Time (seconds): 2.47
Total CPU Time (seconds): 2.13
Maximum Memory Usage (kilobytes): 159780
Working Directory Disk Usage (kilobytes): 0
Results Directory Size (kilobytes):
417 .\Analysis1
Run Completed
Fri Jul 18, 2003 15:44:55
