查看: 18295|回复: 7
[求助] 帮忙看下Remove的元素树
发表于 2010-11-29 09:25:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(1) Feature element tree
   PRO_E_FEATURE_TREE
      |-- PRO_E_FEATURE_TYPE
      |-- PRO_E_STD_FEATURE_NAME
      |-- PRO_E_RM_SURF_REF_TYPE
      |-- PRO_E_RM_SURF_ATTACH_TYPE
      |-- PRO_E_RM_SURF_SRF_REFS
      |    |-- PRO_E_STD_SURF_COLLECTION_APPL
      |    |-- PRO_E_STD_EXCL_CNTRS
      |         |-- PRO_E_STD_EXCL_CNTRS_ONE_CNTR
      |              |-- PRO_E_STD_EXCL_CNTR_SRF_REF
      |              |-- PRO_E_STD_EXCL_CNTR_EDGE_REF
      |-- PRO_E_RM_SURF_CRV_REFS
      |    |-- PRO_E_STD_CURVE_COLLECTION_APPL
(2) Feature elements table
Element Id                     Element Name              Data Type                 Valid Values
PRO_E_FEATURE_TYPE                Feature Type           PRO_VALUE_TYPE_INT        PRO_FEAT_RM_SURF
PRO_E_STD_FEATURE_NAME            Feature Name           PRO_VALUE_TYPE_WSTRING    Wide character string
PRO_E_RM_SURF_REF_TYPE            Reference type         PRO_VALUE_TYPE_INT        Note-1
PRO_E_RM_SURF_ATTACH_TYPE         Attachment type        PRO_VALUE_TYPE_INT        Note-2
PRO_E_RM_SURF_SRF_REFS            Surface references     Compound                  Note-3
PRO_E_STD_SURF_COLLECTION_APPL    Exclude surfaces       PRO_VALUE_TYPE_SELECTION  Note-4
PRO_E_STD_EXCL_CNTRS              Exclude loop           Array                     Note-5
PRO_E_RM_SURF_CRV_REFS            Curve-chain references Compound                  Note-6
PRO_E_STD_CURVE_COLLECTION_APPL   Chains to remove       PRO_VALUE_TYPE_SELECTION  Note-7
(3) Notes
   Note-1 : Value type is ProRmSurfRefType. The value of this element determines which
            references compound (PRO_E_RM_SURF_SRF_REFS/PRO_E_RM_SURF_CRV_REFS) is visible.
   Note-2 : Value type is ProRmSurfAttachType. The value of this element determines whether
            the geometry of the feature will created as a separate quilt or will be attached
            to the selected surface/quilt.
   Note-3 : Compound of surface references.
            This element is required if PRO_E_RM_SURF_REF_TYPE is PRO_RM_SURF_SRF_REF.
   Note-4 : Select the surfaces to be removed from the part.
            Multiple selection allowed. This element is required provided
            PRO_E_RM_SURF_SRF_REFS compound is visible. See Note-1.
   Note-5 : Array of excluded contours. Optional. See ProExclCntrs.h
   Note-6 : Compound of crv references.
            This element is required if PRO_E_RM_SURF_REF_TYPE is PRO_RM_SURF_CRV_REF.
   Note-7 : Select a single closed loop of one sided edges. This element is required provided
            PRO_E_RM_SURF_CRV_REFS compound is visible. See Note-1.
PRO_E_STD_SURF_COLLECTION_APPL    Exclude surfaces       是排除曲面的设置,那要移除的曲面在哪设置啊
发表于 2010-12-30 13:18:57 | 只看该作者
高手指点下?还没搞定
发表于 2011-1-5 09:59:50 | 只看该作者
沒有實做過,不過也跟CopyGeometry一樣,
PRO_E_STD_SURF_COLLECTION_APPL   是 ProCollection 類型
发表于 2011-1-8 13:01:57 | 只看该作者
谢谢!真是"听君一席话,胜读十年书"啊,
终于搞定了,但是还有一个地方不是很明白,
ProSrfcollinstrAlloc(PRO_SURFCOLL_SINGLE_SURF,PRO_B_FALSE,&srf_coll_instr);
ProSrfcollrefAlloc(PRO_SURFCOLL_REF_SINGLE,srf_ref,&srf_coll_ref);
这两个函数的第一个参数是什么意思
发表于 2011-1-8 13:12:20 | 只看该作者
3# hust65
可不可以加你QQ啊,当然,上班时间不会打扰你的
我QQ:568872281
加我时打上:hust65
发表于 2011-1-8 13:18:48 | 只看该作者
ProSrfcollectionAlloc(&srf_coll);分配内存
ProCollectionFree(&srf_coll);//不能释放内存
发表于 2011-1-10 10:13:03 | 只看该作者
5# hyccai
我沒有QQ耶,有問題還是可以一起討論
只是現在真的是忙翻了
你問的問題有些我也沒做過,讓我也有學習的機會
发表于 2011-1-13 09:24:38 | 只看该作者
大家有没有国标库PTC的,有的越具体越好,就是里面国标的东西基本都有,麻烦发给我啊
GMT+8, 2025-4-5 10:25 , Processed in 0.024004 second(s), 11 queries , Gzip On, Redis On.
