双11·3D打印优惠活动
查看: 16517|回复: 3
[求助] 请教高高高手api简单干涉的函数是哪个,找了好久,谢天谢地谢谢您
发表于 2010-12-11 21:46:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教高高高手api简单干涉的函数是哪个,找了好久,谢天谢地谢谢您!!!
发表于 2010-12-12 09:46:56 | 只看该作者
UF_MODL_check_interference
这是检查干涉函数
下面是具体例子
#include <stdio.h>
#include <uf.h>
#include <uf_part.h>
#include <uf_defs.h>
#include <uf_modl.h>
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
static int report( char *file, int line, char *call, int irc)
  if (irc)
     char    messg[133];
     printf("%s, line %d:  %s\n", file, line, call);
     (UF_get_fail_message(irc, messg)) ?
       printf("    returned a %d\n", irc) :
       printf("    returned error %d:  %s\n", irc, messg);
  return(irc);
static void do_ugopen_api(void)
  char    *edge_length[3] = {"5.0", "5.0", "5.0"};
  char    *prtnam = "check_interference";
  char    *dia = "3.0";
  char    *height = "10.0";
  double  cyl_dir[3] = {0.0, 0.0, 1.0};
  double  origin[3] = {0.0, 0.0, 0.0};
  int     num_tools;
  int     results[2];
  tag_t   target;
  tag_t   tools[2];
  tag_t   feat_tag;
  tag_t   part_tag;
  UF_FEATURE_SIGN create = UF_NULLSIGN;
  /* Open a new part */
  UF_CALL( UF_PART_new(prtnam, METRIC, &part_tag) );
  /* Create a block of dimensions 5, 5, 5 */
  UF_CALL(UF_MODL_create_block1(create, origin, edge_length, &feat_tag));
  UF_CALL(UF_MODL_ask_feat_body(feat_tag, &target))   ;
  /* Create a cylinder */
  UF_CALL(UF_MODL_create_cyl1(create, origin, height, dia, cyl_dir, &feat_tag));
  UF_CALL(UF_MODL_ask_feat_body(feat_tag, &tools[0]));
  /* Create another cylinder not intersecting block */
  origin[0] = 10.0;
  origin[1] = 0.0;
  origin[2] = 0.0;
  UF_CALL(UF_MODL_ask_feat_body(feat_tag, &tools[1]));
  /* check interference of the tool bodies against the target */
  num_tools = 2;
  UF_CALL(UF_MODL_check_interference( target, num_tools, tools, results ));
  if (results[0] != 1 || results[1] != 2)
     printf("*** ERROR from UF_MODL_check_interference ***\n");
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int param_len)
  if (!UF_CALL(UF_initialize()))
    do_ugopen_api();
    UF_CALL(UF_terminate());
int ufusr_ask_unload(void)
  return (UF_UNLOAD_IMMEDIATELY);
发表于 2010-12-12 20:03:33 | 只看该作者
哦,原来是UF_MODL_check_interference,我试试,请问兄弟这个例子是从帮助文件中找的吗还是有什么好书?
头像被屏蔽
发表于 2010-12-13 14:13:13 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-10-18 02:06 , Processed in 0.052214 second(s), 11 queries , Gzip On, Redis On.
