查看: 15647|回复: 0
[求助] 刀具在曲面边界处的加工方式
发表于 2010-12-14 20:41:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
诚心请教,曲面加工中边界设置(又叫高级设置)对话框中的各项的意思,
还有各术语的含义。涕零!
advanced settings:
                        reset
                        at surface(solid face)edge,roll tool:
                                                      automatically(based on geometry)
                                                      only between surfaces(solid faces)
                                                      over all edges
                         sharp corner tolerance(at surface/face edge):
                                                      distance
                                                      % of cut tolerance
                         skip hidden face test for solid body
                         check for internal sharp corner
GMT+8, 2025-4-30 04:15 , Processed in 0.020836 second(s), 11 queries , Gzip On, Redis On.
