查看: 20819|回复: 4
[求助] 请高手帮忙调试_看哪里出问题了
发表于 2011-1-11 12:04:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
运行编译后的DLL时,当选择实体边时就会出错。
请高手帮忙查看哪里出问题了,用NX6.0库和NX6.0里运行。
以下附件是源码和.界面文件
发表于 2011-1-11 12:04:50 | 只看该作者
  1. //==============================================================================
  2. //   WARNING!!  This file is overwritten by the UIStyler each time the Styler
  3. //   file is saved.
  4. //
  5. //        Filename:  UIStylerSelectionExample.hxx
  6. //
  7. //        This file was generated by the NX User Interface Styler
  8. //        Created by: jawale
  9. //        Version: NX 5
  10. //              Date: 12-13-2006
  11. //              Time: 11:56
  12. //
  13. //   This template file is overwritten each time the UIStyler dialog is
  14. //   saved.  Any modifications to this file will be lost.
  15. //==============================================================================
  16. #ifndef UISTYLERSELECTIONEXAMPLE_H_INCLUDED
  17. #define UISTYLERSELECTIONEXAMPLE_H_INCLUDED
  18. //------------------------------------------------------------------------------
  19. // These includes are needed for the following template code
  20. //------------------------------------------------------------------------------
  21. #include <uf_defs.h>
  22. #include <iostream>
  23. #include <NXOpen/Session.hxx>
  24. #include <NXOpen/UI.hxx>
  25. #include <NXOpen/Callback.hxx>
  26. #include <NXOpen/NXException.hxx>
  27. #include <NXOpen/UIStyler_Dialog.hxx>
  28. #include <NXOpen/UIStyler_StylerEvent.hxx>
  29. #include <NXOpen/NXMessageBox.hxx>
  30. #include <NXOpen/UIStyler_BitMap.hxx>
  31. #include <NXOpen/UIStyler_CollapsibleGroup.hxx>
  32. #include <NXOpen/UIStyler_DialogItem.hxx>
  33. #include <NXOpen/UIStyler_GroupBox.hxx>
  34. #include <NXOpen/UIStyler_LabelItem.hxx>
  35. #include <NXOpen/UIStyler_RealItem.hxx>
  36. #include <NXOpen/UIStyler_StringItem.hxx>
  37. #include <NXOpen/UIStyler_Toggle.hxx>
  38. //------------------------------------------------------------------------------
  39. // Namespaces needed for following template
  40. //------------------------------------------------------------------------------
  41. using namespace std;
  42. using namespace NXOpen;
  43. using namespace NXOpen::UIStyler;
  44. //------------------------------------------------------------------------------
  45. // Forward declaration for Class
  46. //------------------------------------------------------------------------------
  47. class UIStylerSelectionExample;
  48. //------------------------------------------------------------------------------
  49. // Declaration of global variables
  50. //------------------------------------------------------------------------------
  51. extern UIStylerSelectionExample *theUIStylerSelectionExample;
  52. class UIStylerSelectionExample
  53. {
  54.     // class members
  55. public:
  56.     static Session *theSession;
  57.     static UI *theUI;
  58.     static bool isDisposeCalled;
  59.     UIStylerSelectionExample();
  60.     ~UIStylerSelectionExample();
  61.     void Dispose();
  62.     NXOpen::UIStyler::DialogResponse Show();
  63.     void RegisterWithUiMenu();
  64.     //------------------------- UIStyler Callback Prototypes -----------------------
  65.     // The following member function prototypes define the callbacks
  66.     // specified in your UIStyler built dialog.  You are REQUIRED to
  67.     // create the associated function for each prototype.  You must
  68.     // use the same function name and parameter list when creating
  69.     // your callback function.
  70.     //------------------------------------------------------------------------------
  71.     NXOpen::UIStyler::DialogState apply_cb(NXOpen::UIStyler::StylerEvent* eventObject);
  72.     NXOpen::UIStyler::DialogState bend_radius_cb(NXOpen::UIStyler::StylerEvent* eventObject);
  73.     NXOpen::UIStyler::DialogState constructor_cb(NXOpen::UIStyler::StylerEvent* eventObject);
  74.     NXOpen::UIStyler::DialogState ok_cb(NXOpen::UIStyler::StylerEvent* eventObject);
  75.     NXOpen::UIStyler::DialogState remove_surface_self_intersections_cb(NXOpen::UIStyler::StylerEvent* eventObject);
  76.     NXOpen::UIStyler::DialogState tolerance_cb(NXOpen::UIStyler::StylerEvent* eventObject);
  77. NXOpen::UIStyler::LabelItem *GetChangeLabel1();
  78. private:
  79.     NXOpen::UIStyler::Dialog *theDialog;
  80.     NXOpen::UIStyler::DialogItem *changeDialog;
  81.     NXOpen::UIStyler::GroupBox *changeGrBeg1;
  82.     NXOpen::UIStyler::BitMap *changeBitmap1;
  83.     NXOpen::UIStyler::LabelItem *changeLabel1;
  84.     NXOpen::UIStyler::StringItem *changeStr0;
  85.     NXOpen::UIStyler::CollapsibleGroup *changeCgBeg5;
  86.     NXOpen::UIStyler::Toggle *changeToggle6;
  87.     NXOpen::UIStyler::RealItem *changeReal6;
  88.
  89.     void InitializeUIStylerDialog();
  90. };
  91. #endif // UIStylerSelectionExample_H_INCLUDED
复制代码
发表于 2011-1-11 12:12:14 | 只看该作者
  1. // Filename: UIStylerSelectionExample.cxx
  2. //------------------------------------------------------------------------------
  3. // These includes are needed for the following template code
  5. #include <map>
  6. #include <algorithm>
  7. #include <NXOpen/UI.hxx>
  8. #include <NXOpen/UIStyler_Styler.hxx>
  9. #include <NXOpen/Selection.hxx>
  10. #include <NXOpen/NXObject.hxx>
  11. #include <NXOpen/UIStyler_LabelItem.hxx>
  12. #include <uf_defs.h>
  13. #include <NXOpen/Builder.hxx>
  14. #include <NXOpen/Edge.hxx>
  15. #include <NXOpen/EdgeMultipleSeedTangentRule.hxx>
  16. #include <NXOpen/Features_Block.hxx>
  17. #include <NXOpen/Features_EdgeBlendBuilder.hxx>
  18. #include <NXOpen/Features_Feature.hxx>
  19. #include <NXOpen/Features_FeatureBuilder.hxx>
  20. #include <NXOpen/Features_FeatureCollection.hxx>
  21. #include <NXOpen/GeometricUtilities_BlendLimitsData.hxx>
  22. #include <NXOpen/ObjectList.hxx>
  23. #include <NXOpen/Part.hxx>
  24. #include <NXOpen/PartCollection.hxx>
  25. #include <NXOpen/ScCollector.hxx>
  26. #include <NXOpen/ScCollectorCollection.hxx>
  27. #include <NXOpen/ScRuleFactory.hxx>
  28. #include <NXOpen/SelectionIntentRule.hxx>
  29. #include <NXOpen/Session.hxx>
  30. #include <NXOpen/TaggedObjectList.hxx>
  31. #include <uf_object_types.h>
  32. #include <uf_ui_types.h>
  33. #include "UIStylerSelectionExample.hxx"
  34. using namespace NXOpen;
  35. std::map<const char*, NXOpen::NXObject*> htEdges;
  36. std::map<const char*, NXOpen::NXObject*>::iterator htEdgesIterator;
  37. //------------------------------------------------------------------------------
  38. // Initialize static variables
  39. //------------------------------------------------------------------------------
  40. Session *(UIStylerSelectionExample::theSession) = NULL;
  41. UI *(UIStylerSelectionExample::theUI) = NULL;
  42. bool UIStylerSelectionExample::isDisposeCalled = false;
  43. //------------------------------------------------------------------------------
  44. // Declaration of global variables
  45. //------------------------------------------------------------------------------
  46. UIStylerSelectionExample *theUIStylerSelectionExample;
  47. //------------------------------------------------------------------------------
  48. // Constructor for NX Styler class
  49. //------------------------------------------------------------------------------
  50. UIStylerSelectionExample::UIStylerSelectionExample()
  51. {
  52. try
  53. {
  54. // Initialize the NX Open C++ API environment
  55. UIStylerSelectionExample::theSession = NXOpen::Session::GetSession();
  56. UIStylerSelectionExample::theUI = UI::GetUI();
  57. // Initialize the Open C API environment
  58. UIStylerSelectionExample::isDisposeCalled = false;
  59. NXOpen::UIStyler::Styler* theStyler = theUI->Styler();
  60. theDialog = theStyler->CreateStylerDialog("UIStylerSelectionExample.dlg");
  61. InitializeUIStylerDialog();
  62. }
  63. catch (const NXOpen::NXException& ex)
  64. {
  65. // ---- Enter your exception handling code here -----
  66. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  67. }
  68. return;
  69. }
  71. // This method is required for UI styler dialog creation
  72. //------------------------------------------------------------------------------
  73. void UIStylerSelectionExample::InitializeUIStylerDialog()
  74. {
  75. try
  76. {
  77. changeDialog = (NXOpen::UIStyler::DialogItem*)theDialog->GetStylerItem("UF_STYLER_DIALOG_INDEX", NXOpen::UIStyler::Dialog::ItemTypeDialogItem);
  78. changeDialog->AddConstructHandler(make_callback(this, &UIStylerSelectionExample::constructor_cb), false);
  79. changeDialog->AddOkayHandler(make_callback(this, &UIStylerSelectionExample::ok_cb), false);
  80. changeDialog->AddApplyHandler(make_callback(this, &UIStylerSelectionExample::apply_cb), false);
  81. changeGrBeg1 = (NXOpen::UIStyler::GroupBox*)theDialog->GetStylerItem("GR_BEG_1", NXOpen::UIStyler::Dialog::ItemTypeGroupBox);
  82. changeBitmap1 = (NXOpen::UIStyler::BitMap*)theDialog->GetStylerItem("BITMAP_1", NXOpen::UIStyler::Dialog::ItemTypeBitmap);
  83. changeLabel1 = (NXOpen::UIStyler::LabelItem*)theDialog->GetStylerItem("LABEL_1", NXOpen::UIStyler::Dialog::ItemTypeLabelItem);
  84. changeStr0 = (NXOpen::UIStyler::StringItem*)theDialog->GetStylerItem("STR_0", NXOpen::UIStyler::Dialog::ItemTypeStringItem);
  85. changeStr0->AddActivateHandler(make_callback(this, &UIStylerSelectionExample::bend_radius_cb), false);
  86. changeCgBeg5 = (NXOpen::UIStyler::CollapsibleGroup*)theDialog->GetStylerItem("CG_BEG_5", NXOpen::UIStyler::Dialog::ItemTypeCollapsibleGroup);
  87. changeToggle6 = (NXOpen::UIStyler::Toggle*)theDialog->GetStylerItem("TOGGLE_6", NXOpen::UIStyler::Dialog::ItemTypeToggle);
  88. changeToggle6->AddValueChangedHandler(make_callback(this, &UIStylerSelectionExample::remove_surface_self_intersections_cb), false);
  89. changeReal6 = (NXOpen::UIStyler::RealItem*)theDialog->GetStylerItem("REAL_6", NXOpen::UIStyler::Dialog::ItemTypeRealItem);
  90. changeReal6->AddActivateHandler(make_callback(this, &UIStylerSelectionExample::tolerance_cb), false);
  91. }
  92. catch (const NXOpen::NXException& ex)
  93. {
  94. // ---- Enter your exception handling code here -----
  95. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  96. }
  97. return;
  98. }
  99. NXOpen::UIStyler::LabelItem* UIStylerSelectionExample::GetChangeLabel1()
  100. {
  101. return changeLabel1;
  102. }
  103. extern "C" DllExport void ufusr(char *param, int *retcod, int param_len)
  104. {
  105. try
  106. {
  107. NXOpen::UIStyler::DialogResponse response;
  108. theUIStylerSelectionExample = new UIStylerSelectionExample();
  109. // The following method shows the dialog immediately
  110. response = theUIStylerSelectionExample->Show();
  111. theUIStylerSelectionExample->Dispose();
  112. }
  113. catch (const NXOpen::NXException& ex)
  114. {
  115. // ---- Enter your exception handling code here -----
  116. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  117. }
  118. } // User exit ends
  119. extern "C" DllExport int ufusr_ask_unload()
  120. {
  121. // return (int)Session::LibraryUnloadOptionExplicitly;
  122. return (int)Session::LibraryUnloadOptionImmediately;
  123. // return (int)Session::LibraryUnloadOptionAtTermination;
  124. }
  125. extern "C" DllExport void ufusr_cleanup(void)
  126. {
  127. try
  128. {
  129. if(UIStylerSelectionExample::isDisposeCalled == false)
  130. {
  131. theUIStylerSelectionExample->Dispose();
  132. }
  133. UIStylerSelectionExample::isDisposeCalled = true;
  134. }
  135. catch (const NXOpen::NXException& ex)
  136. {
  137. // ---- Enter your exception handling code here -----
  138. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  139. }
  140. return;
  141. }
  142. NXOpen::UIStyler::DialogResponse UIStylerSelectionExample::Show()
  143. {
  144. NXOpen::UIStyler::DialogResponse retValue = NXOpen::UIStyler::DialogResponseOk;
  145. try
  146. {
  147. retValue = theDialog->Show();
  148. }
  149. catch (const NXOpen::NXException& ex)
  150. {
  151. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  152. }
  153. return retValue;
  154. }
  155. void UIStylerSelectionExample::Dispose()
  156. {
  157. try
  158. {
  159. if (UIStylerSelectionExample::isDisposeCalled == false)
  160. {
  161. delete changeDialog;
  162. delete changeGrBeg1;
  163. delete changeBitmap1;
  164. delete changeLabel1;
  165. delete changeStr0;
  166. delete changeCgBeg5;
  167. delete changeToggle6;
  168. delete changeReal6;
  169. delete theDialog;
  170. }
  171. UIStylerSelectionExample::isDisposeCalled = true;
  172. }
  173. catch (const NXOpen::NXException& ex)
  174. {
  175. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  176. }
  177. return;
  178. }
  179. int sel_cb(std::vector<NXOpen::NXObject *> selectedObject, std::vector<NXOpen::NXObject *> deselectedObjects, NXOpen::SelectionHandle* selectHandle)
  180. {
  181. try
  182. {
  183. std::vector<NXOpen::NXObject *>::iterator selIter;
  184. for (selIter = selectedObject.begin(); selIter != selectedObject.end(); selIter++)
  185. {
  186. htEdges[(*selIter)->JournalIdentifier().GetLocaleText()] = *selIter;
  187. }
  188. for (selIter = deselectedObjects.begin(); selIter != deselectedObjects.end(); selIter++)
  189. {
  190. htEdges.erase((*selIter)->JournalIdentifier().GetLocaleText());
  191. }
  192. int cnt = htEdges.size();
  193. char sel_edges[100];
  194. sprintf(sel_edges, "Select Edges ( %d )", cnt);
  195. theUIStylerSelectionExample->GetChangeLabel1()->SetLabel(NXOpen::NXString(std::string(sel_edges)));
  196. }
  197. catch (const NXOpen::NXException& ex)
  198. {
  199. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  200. }
  201. return NXOpen::UIStyler::DialogStateContinueDialog;
  202. }
  203. int filter_cb(NXOpen::NXObject *selectedObject, NXOpen::Selection::MaskTriple* selectionMask_array, NXOpen::SelectionHandle* selectHandle)
  204. {
  205. try
  206. {
  207. if(std::string(selectedObject->JournalIdentifier().GetText()) == std::string("EDGE * 6 * 1"))
  208. return UF_UI_SEL_REJECT;
  209. else
  210. return UF_UI_SEL_ACCEPT;
  211. }
  212. catch (const NXOpen::NXException& ex)
  213. {
  214. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  215. }
  216. return NXOpen::UIStyler::DialogStateContinueDialog;
  217. }
  218. NXOpen::UIStyler::DialogState UIStylerSelectionExample::constructor_cb(NXOpen::UIStyler::StylerEvent* eventObject)
  219. {
  220. try
  221. {
  222. // Get the selection handle
  223. NXOpen::SelectionHandle *selectH = changeDialog->GetSelectionHandle();
  224. std::vector<NXOpen::Selection::MaskTriple> selectionMask_array;
  225. NXOpen::Selection::MaskTriple selectionMask_arrayElem;
  226. selectionMask_arrayElem.Type = UF_solid_type;
  227. selectionMask_arrayElem.Subtype = UF_solid_edge_subtype;
  228. selectionMask_arrayElem.SolidBodySubtype = UF_UI_SEL_FEATURE_ANY_EDGE;
  229. selectionMask_array.push_back(selectionMask_arrayElem);
  230. UI::GetUI()->SelectionManager()->SetSelectionMask(selectH, NXOpen::Selection::SelectionActionClearAndEnableSpecific, selectionMask_array);
  231. UI::GetUI()->SelectionManager()->SetSelectionCallbacks(selectH, make_callback(&filter_cb), make_callback(&sel_cb));
  232. changeToggle6->SetItemValue(true);
  233. changeStr0->SetItemValue("5.0");
  234. changeLabel1->SetLabel("Select Edges (0)");
  235. }
  236. catch (const NXOpen::NXException& ex)
  237. {
  238. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  239. }
  240. return NXOpen::UIStyler::DialogStateContinueDialog;
  241. }
  242. NXOpen::UIStyler::DialogState UIStylerSelectionExample::ok_cb(NXOpen::UIStyler::StylerEvent* eventObject)
  243. {
  244. try
  245. {
  246. NXOpen::UIStyler::DialogState LOCAL_state = apply_cb(eventObject);
  247. return LOCAL_state;
  248. }
  249. catch (const NXOpen::NXException& ex)
  250. {
  251. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  252. }
  253. return NXOpen::UIStyler::DialogStateExitDialog;
  254. }
  255. NXOpen::UIStyler::DialogState UIStylerSelectionExample::apply_cb(NXOpen::UIStyler::StylerEvent* eventObject)
  256. {
  257. try
  258. {
  259. Part *workPart(theSession->Parts()->Work());
  260. Part *displayPart(theSession->Parts()->Display());
  261. Session::UndoMarkId markId1;
  262. markId1 = theSession->SetUndoMark(Session::MarkVisibilityVisible, "Start");
  263. Features::Feature *nullFeatures_Feature(NULL);
  264. Features::EdgeBlendBuilder *edgeBlendBuilder1;
  265. edgeBlendBuilder1 = workPart->Features()->CreateEdgeBlendBuilder(nullFeatures_Feature);
  266. theSession->SetUndoMarkName(markId1, "Edge Blend");
  267. ScCollector *scCollector1;
  268. scCollector1 = workPart->ScCollectors()->CreateCollector();
  269. std::vector<Edge *> seedEdges1;
  270. Features::Block *block1(dynamic_cast<Features::Block *>(workPart->Features()->FindObject("BLOCK(1)")));
  271. for (htEdgesIterator = htEdges.begin(); htEdgesIterator != htEdges.end(); ++htEdgesIterator)
  272. {
  273. Edge *edge1(dynamic_cast<Edge *>(htEdgesIterator->second));
  274. seedEdges1.push_back(edge1);
  275. }
  276. EdgeMultipleSeedTangentRule *edgeMultipleSeedTangentRule1;
  277. edgeMultipleSeedTangentRule1 = workPart->ScRuleFactory()->CreateRuleEdgeMultipleSeedTangent(seedEdges1, 0.5, true);
  278. std::vector<SelectionIntentRule *> rules1(1);
  279. rules1[0] = edgeMultipleSeedTangentRule1;
  280. scCollector1->ReplaceRules(rules1, false);
  281. Session::UndoMarkId markId2;
  282. markId2 = theSession->SetUndoMark(Session::MarkVisibilityInvisible, "Edge Blend");
  283. edgeBlendBuilder1->LimitsListData()->CapsList()->Clear(ObjectList::DeleteOptionDelete);
  284. edgeBlendBuilder1->SetTolerance(0.0254);
  285. edgeBlendBuilder1->SetAllInstancesOption(false);
  286. edgeBlendBuilder1->SetRemoveSelfIntersection(true);
  287. edgeBlendBuilder1->SetConvexConcaveY(false);
  288. edgeBlendBuilder1->SetRollOverSmoothEdge(true);
  289. edgeBlendBuilder1->SetRollOntoEdge(true);
  290. edgeBlendBuilder1->SetMoveSharpEdge(true);
  291. edgeBlendBuilder1->SetOverlapOption(Features::EdgeBlendBuilder::OverlapAnyConvexityRollOver);
  292. edgeBlendBuilder1->SetBlendOrder(Features::EdgeBlendBuilder::OrderOfBlendingConvexFirst);
  293. edgeBlendBuilder1->SetSetbackOption(Features::EdgeBlendBuilder::SetbackSeparateFromCorner);
  294. int csIndex1;
  295. csIndex1 = edgeBlendBuilder1->AddChainset(scCollector1, "5");
  296. Features::Feature *feature1;
  297. feature1 = edgeBlendBuilder1->CommitFeature();
  298. theSession->DeleteUndoMark(markId2, NULL);
  299. edgeBlendBuilder1->Destroy();
  300. htEdges.clear();
  301. changeLabel1->SetLabel("Select Edges (0)");
  302. }
  303. catch (const NXOpen::NXException& ex)
  304. {
  305. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  306. }
  307. return NXOpen::UIStyler::DialogStateContinueDialog;
  308. }
  309. NXOpen::UIStyler::DialogState UIStylerSelectionExample::bend_radius_cb(NXOpen::UIStyler::StylerEvent* eventObject)
  310. {
  311. try
  312. {
  313. }
  314. catch (const NXOpen::NXException& ex)
  315. {
  316. // ---- Enter your exception handling code here -----
  317. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  318. }
  319. // Callback acknowledged, do not terminate dialog
  320. return NXOpen::UIStyler::DialogStateContinueDialog;
  321. // or Callback acknowledged, terminate dialog.
  322. // return NXOpen::UIStyler::DialogStateExitDialog;
  323. }
  324. NXOpen::UIStyler::DialogState UIStylerSelectionExample::remove_surface_self_intersections_cb(NXOpen::UIStyler::StylerEvent* eventObject)
  325. {
  326. try
  327. {
  328. }
  329. catch (const NXOpen::NXException& ex)
  330. {
  331. // ---- Enter your exception handling code here -----
  332. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  333. }
  334. // Callback acknowledged, do not terminate dialog
  335. return NXOpen::UIStyler::DialogStateContinueDialog;
  336. // or Callback acknowledged, terminate dialog.
  337. // return NXOpen::UIStyler::DialogStateExitDialog;
  338. }
  339. NXOpen::UIStyler::DialogState UIStylerSelectionExample::tolerance_cb(NXOpen::UIStyler::StylerEvent* eventObject)
  340. {
  341. try
  342. {
  343. }
  344. catch (const NXOpen::NXException& ex)
  345. {
  346. UIStylerSelectionExample::theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
  347. }
  348. return NXOpen::UIStyler::DialogStateContinueDialog;
  349. }
复制代码
发表于 2011-5-11 20:01:08 | 只看该作者
最近也一直在研究,帮你看看吧。不知道能不能解决!!
发表于 2011-9-13 13:52:05 | 只看该作者
没有用过啊
GMT+8, 2025-10-21 08:02 , Processed in 0.034351 second(s), 13 queries , Gzip On, Redis On.
