查看: 16384|回复: 2
[讨论] 选中component后遍历该component的body(带源码)
发表于 2011-1-21 22:27:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用SelectWithSingleDialog选中一个component得到component_tag,想要得到所选component中body的数量,代码如下:
        Dim component_tag As NXOpen.Tag
        Dim component1 As Assemblies.Component
        Dim all_bodies() As Body
        Dim body_count As Integer
        SelectWithSingleDialog(.......component_tag...........)(此处省略)
        component1 = ctype(NXObjectManager.Get(component_tag), Assemblies.Component)
        all_bodies=component1.Bodies.ToArray()
        body_count=all_bodies.length
        MsgBox("Count of Bodies in select Part: " & body_count)
但是提示错误信息,
'part' is not a member of 'NXopen.Assemblies.Component'.
请各位路过的高手帮小弟看看怎么改,多谢了~~~~~~~~~~~~~~~~~~
发表于 2011-1-22 21:02:47 | 只看该作者
help!!!!!!!!急死人也!
发表于 2011-1-23 21:32:02 | 只看该作者
GMT+8, 2025-4-22 14:32 , Processed in 0.019784 second(s), 11 queries , Gzip On, Redis On.
