查看: 16567|回复: 0
[转贴] New features in Laminate Tools version 4.1
发表于 2011-2-22 09:21:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
New features in Laminate Tools version 4.1  (first release, since launch of version 4.0)
Geometry
  • enabled the import of 3D curves from CAD, and other geometric entities for future enhancements
  • implemented new embedded SOLIDWORKS interface, for easy ply definition
Design
  • enabled ply Split (dart) definitions as curves unrelated to the mesh, for easier generation of accurate flat ply patterns
  • added method of area picking bounded by an imported Boundary curve
  • added method of area picking by similar element normal orientation
  • enhanced the area picking method by visible element set
  • added support for import/export of element sets in Session files
Manufacturing
  • enabled Boundary curve definitions for easy and accurate flat ply outline pattern generation (incl. cutouts)
  • easy ply drop-off flat patterns now possible via imported boundary curves
  • added ply name to flat pattern DXF file, as a new pattern export option
  • introduced option to control the default exported IGES file extension name, for improved compatibility
Analysis
  • enhanced the Nastran export "merge" feature, to scan the mesh and property ids for best merged results
  • added support for the new Ansys element shell type 281
  • enabled Ansys properties export including global ply definition (zero thickness at drop-off)
  • added Laminate Tools material names to Nastran export files, for easier identification and re-use
Post-processing
  • Enabled basic output of generated failure results to the Altair HyperWorks H3D format, with further enhancements under way
User Interface
  • implemented COM Server Automation functionality, for remote control via custom client applications
  • enabled user-selected licence at launch, useful for multi-licence sites
  • several bugs corrected, and processing improved
  • software updates in line with PlyMatch 2010 system upgrade, communication with the hardware re-engineered
  • enhanced error reporting, to troubleshoot operations
  • recording timer shows permanently during recording, and is stamped in the recording
  • increased best recording quality to 15 frames per second
  • available probe files now appear automatically in selection boxes
  • relaxed tolerance of camera movement, for smoother animation
  • relaxed default calibration tolerance for easier setup
www.caefinder.com
GMT+8, 2025-2-7 21:46 , Processed in 0.023233 second(s), 10 queries , Gzip On, Redis On.
