查看: 16807|回复: 3
[分享] 西门子发布Solid Edge ST3的最新补丁MP3
发表于 2011-3-8 08:06:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Dear Solid Edge Customer:
We are pleased to inform you that Maintenance Pack 3 (MP3) for Solid Edge ST3 is now available for download on the GTAC FTP server.
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
Sincerely,
The Solid Edge Team
Download Location:
Solid Edge (Maintenance Pack)
Solid Edge Insight Connect (Maintenance Pack)
Solid Edge Viewer (Maintenance Pack)
Solid Edge Mold Tooling (Maintenance Pack)
Solid Edge Insight Server WSS 3.0 (Maintenance Pack)
Solid Edge Insight Server SharePoint Foundation 2010 (Maintenance Pack)
https://ftp.ugs.com/solid_edge/ST3/InsightServerSharePointFoundation2010/
Solid Edge Embedded Client (Maintenance Pack)
Solid Edge Embedded Client Structure Editor (Maintenance Pack)
Solid Edge Embedded Client Administrator (full install)
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation.
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: https://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
This Maintenance Pack addresses the following PRs:
===API===
PR 6426380: Not getting Colors in SEPartReader, SEReader
===Assembly===
PR 1824462: Fixed crashes identified by crashlog files
PR 1826468: Path name length is limited to 129 characters in Property Manager
PR 6462576: Solid Edge crashes after selecting part of SysLib after placing it
PR 6465652: Abort if save is clicked while config file open dialog is active
PR 1829176: Unable to activate zones with double-click
PR 6471148: Display performance is slow on rotations and zooming
PR 6474039: Fixed crashes identified by crashlog files
PR 1815765: Unable to open CATIA V5 R20 part files
PR 1828742: Solid Edge Frame Design / Routing API.
PR 6417945: the default location of the Quickbar / Assembly Pathfinder is not correct in Sketch
PR 6429834: Patterned frame members list is on separate line item in Parts List
PR 6461646: scroll to part results being obscured by the relation tree
PR 6470893: Solid Edge is slow to open a Parasolid assembly
PR 1819591: Assembly aborts when creating relationships
PR 6469074: Assembly reports are not picking up custom property values
PR 6472642:  New Menu Starting Wrong Template
===Draft===
PR 6327121: Abort on close if dim tracker has been run and something remained in the select set
PR 6357213: Callout Text gets merged if Alignment is changed to Center or Right
PR 6412216: Dimensions detach on update
PR 6427966: Part aborts revolving a synchronous cutout
PR 6429679: Exiting profile causes an abort
PR 6454096: Cannot exit edit boundary environment after ctrl-drag of 2d object
PR 6456030: Solid Edge open DWG Options/Review are not giving the correct sheet information
PR 6456838: Can't place a dimension in a Detail View using dimension axis
PR 6464949: Parts list moves up and left by .175 mm when opened
PR 1816750: Cannot select elliptical arcs in hole table command
PR 2162210: "Thread Display Mode" changes value when Apply button is clicked on other property pages
===Insight/View & Markup===
PR 6457292: Failed to generate document libraries property mapping information
PR 6465929: Insight server log files cannot be generated for SharePoint 2010
PR 6466137: Registry key VMOnSaveEmbedViewingLink not delivered in ST 3
===Part/Profile/Sheet Metal===
PR 1776878: Callout for %HS is incorrect on Part Copies
PR 1824462: a crash that may occur when imprinting curves
PR 6367518: If Relationship Colors is on, no indication when dimensions are failed
PR 6434556: a crash occurring when locating items in pathfinder after closing a file
PR 6453116: Immediately after rotate you see a flash of the model in a different orientation
PR 6456053: Sync Hole gets deleted if it’s used sketch is deleted after a Move to Sync
PR 6467561: the Solid Edge process hangs around after selecting a region then exiting
PR 6468272: Unable to edit a dimension value with a key-in after scrolling with mouse wheel
PR 1809044: a crash is occurring when trying to open a Solid Edge file
PR 6471224: the concentric live rules turning red when using local symmetry option
PR 6471336: Dimension display disappears during edit formula
PR 6473059: sync move appearing sluggish on keypoint locate
PR 6474371: Cannot pattern a hem
PR 6475818: Send Mail & Crashlog tracking failing under Lotus Notes
PR 1827775: Displaying the FOP table takes a long time
PR 2163514: "Show Only Overridden Variables" of the family of parts not being displayed
PR 6477746: Cylinder from a Lofted Flange in ordered sheet metal part has incorrect flat result
发表于 2011-3-8 10:03:50 | 只看该作者
全阴文的压
发表于 2011-3-8 15:49:33 | 只看该作者
从头到尾也看不出是啥意思。进去貌似还得有帐号和密码才行。
发表于 2011-3-8 18:33:35 | 只看该作者
哈哈 西门子出品就是英文,还好没整德文
GMT+8, 2025-4-22 22:41 , Processed in 0.025477 second(s), 11 queries , Gzip On, Redis On.
