查看: 19776|回复: 6
怎么获得产品下面一个零件的document信息啊?
发表于 2011-3-17 22:20:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CATDocument * pProductDocument = NULL;
rc = CATDocumentServices::OpenDocument("E:\\14V_1\\ass2\\r14WK.CATProduct",pProductDocument);
if ( FAILED(rc) || (NULL == pProductDocument) )  AfxMessageBox(_T("2!"));
/* 2. Retrieves Root Product   */
// Begin navigation through the document => start with the RootProduct.
CATIDocRoots* piDocRootsOnDoc = NULL;
rc = pProductDocument->QueryInterface(IID_CATIDocRoots,
  (void**) &piDocRootsOnDoc);
if ( FAILED(rc) ) AfxMessageBox(_T("3!"));
// get the root product which is the first element of root elements
CATListValCATBaseUnknown_var * pRootProducts =
  piDocRootsOnDoc->GiveDocRoots();
CATIProduct_var spRootProduct = NULL_var;
     if (pRootProducts && pRootProducts->Size())
  spRootProduct = (*pRootProducts)[1];
          delete   pRootProducts;
    pRootProducts=NULL;
     piDocRootsOnDoc->Release();
// Get CATIProduct handle on the root product.
CATIProduct *piProductOnRoot = NULL;
rc = spRootProduct->QueryInterface(IID_CATIProduct,
  (void**) &piProductOnRoot);
/*   Imports an existing CATProduct under the root product.   */
CATDocument *pDocPart = NULL;
CATIProduct *piInstanceProd = NULL;
// load the given CATPart
rc = CATDocumentServices::OpenDocument(ifileName,pDocPart);
if ( FAILED(rc) || (NULL==pDocPart) ) AfxMessageBox(_T("4!"));
// agregates an instance of the CATPart root element under the product
rc = OpenResource::AddExternalComponent(piProductOnRoot,pDocPart,&piInstanceProd);
if ( FAILED(rc) ) AfxMessageBox(_T("5!"));
/* 3. Retrieves children under the root   */
// then on a root product, get all the children agregated to it.
CATListValCATBaseUnknown_var*   ListChildren = piProductOnRoot->GetChildren("CATIProduct");
/** @anchor err_2 piProductOnRoot not set to NULL after release */
int numberOfChildren = 0;
numberOfChildren = ListChildren->Size();
CString str;
    str.Format(_T("%d"), numberOfChildren);
     AfxMessageBox(str);
/*  4. For each child, get its partNumber, and InstanceName   */
CATIProduct_var spChild = NULL_var;
    CATIProduct_var spChild1 = NULL_var;
  spChild = (*ListChildren)[6];
    spChild1 = (*ListChildren)[7];
spChild->GetShapeRep(spCATILinkableObject ,"Default", CATPrd3D, TRUE);
  CATDocument * pCATDocument=NULL;
  pCATDocument=spCATILinkableObject->GetDocument();
CATInit  *pInitOnDoc=NULL ;
pCATDocument->QueryInterface(IID_CATInit,(void **) &pInitOnDoc);
CATIPrtContainer *pPrtCont = NULL ;
  pPrtCont=  (CATIPrtContainer*) pInitOnDoc->GetRootContainer("CATIPrtContainer");
    CATIPrtPart_var spPart = pPrtCont->GetPart();
为什么编译的时候能够成功,而在运行的时候到最后一句CATIPrtPart_var spPart = pPrtCont->GetPart();就出错啊?
新人刚学CAA,求高人指教!不甚感激!
这几天被搞得没有信心学了啊....
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2011-3-17 22:23:17 | 只看该作者
上面spCATILinkableObject 已经定义,刚复制漏了一行
CATILinkableObject_var   spCATILinkableObject ;
谢谢!期待高手解答 1# lyy4566
发表于 2011-3-23 09:35:13 | 只看该作者
你试下先得到CATIContainer,再将CATIContainer转化为CATIPrtContainer ~~,你出错很有可能是因为你的CATIPrtContainer 没有成功得到哦~~~
发表于 2011-3-24 16:38:54 | 只看该作者
恩,确实是CATIPrtContainer没有获得成功,现在先获得CATIContainer就可以了,谢谢楼上的 3# linlily0925
发表于 2011-3-26 22:06:11 | 只看该作者
Language="VBSCRIPT"
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set product1 = productDocument1.Product
Set assemblyConvertor1 = product1.GetItem("BillOfMaterial")
Dim arrayOfVariantOfBSTR1(7) 'change number if you have more custom columns/array...
arrayOfVariantOfBSTR1(0) = "Quantity"
arrayOfVariantOfBSTR1(1) = "Part Number"
arrayOfVariantOfBSTR1(2) = "Type"
arrayOfVariantOfBSTR1(3) = "Nomenclature"
arrayOfVariantOfBSTR1(4) = "Revision"
arrayOfVariantOfBSTR1(5) = "Mass" 'in addition of what is by default
arrayOfVariantOfBSTR1(6) = "Density"  'in addition of what is by default
arrayOfVariantOfBSTR1(7) = "Material"  'in addition of what is by default
'assemblyConvertor1.SetCurrentFormat arrayOfVariantOfBSTR1
Dim arrayOfVariantOfBSTR2(1)  'change number if you have more custom columns/array...
arrayOfVariantOfBSTR2(0) = "Quantity"
arrayOfVariantOfBSTR2(1) = "Part Number"
'assemblyConvertor1.SetSecondaryFormat arrayOfVariantOfBSTR2
assemblyConvertor1.Print "TXT", "c:\OutPut_BOM.txt", product1
End Sub
发表于 2011-12-12 10:51:27 | 只看该作者
期待高手解答
发表于 2011-12-17 23:46:42 | 只看该作者
CATSession * CATIASession=NULL;
        CATDocument * pRootDoc  = NULL ;
        CATIASession=CATSession::GetPtrSession();
         CATFrmEditor * piEditor =CATFrmEditor::GetCurrentEditor();
        pRootDoc = piEditor->GetDocument();
        CATInit_var spInit = pRootDoc;
        spInit->Init(TRUE);
        CATIPrtContainer * piPartContainer = (CATIPrtContainer*) spInit->GetRootContainer("CATIPrtContainer");
        if (piPartContainer == NULL)
                return E_FAIL;
        CATIGSMFactory * pFact = NULL;
        rc = piPartContainer -> QueryInterface(IID_CATIGSMFactory, (void**)&pFact);
        if (pFact == NULL)
                return E_FAIL;
        CATIContainer_var    spCont     = pFact ;
        CATIPrtContainer_var spPartCont = spCont;
GMT+8, 2025-9-18 18:33 , Processed in 0.204275 second(s), 12 queries , Gzip On, Redis On.
