Dear Solid Edge Customer:
We are pleased to inform you that Maintenance Pack 4 (MP4) for Solid Edge ST3 is now available for download on the GTAC FTP server.
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation.
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: https://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
This Maintenance Pack addresses the following PRs:
===Assembly===
PR 1833635: Web Publisher result are incorrect if a part has sync and ordered features
PR 1832106: Copied sketch elements, linked to the parent sketch, can be modified or deleted
PR 1835705: A crash occurs when a section view is applied and a part is placed
PR 2161686: Path dimensions disappearing in the frame environment.
PR 2163832: Assembly pathfinder losing display of icons and hide/show boxes
PR 2164176: Crash in XpresRoute when placing dimensions
PR 6426117: Fails to create Chamfer on Frame Pattern occurrence in first attempt
PR 6446233: Mirror assembly command fails with error message
PR 6459239: No user defined properties in assembly query
PR 6463932: Face of the flange should coincide with the endpoint of the line
PR 6471354: SAT file fails to import all bodies
PR 6484211: mass of frame components incorrect
PR 6382855: Change Source button is disabled in the Edit Links command
PR 6427250: pathfinder needs a lot of scroll in a particular workflow
PR 6472286: smart installer does not provide a way to not update already generated parts
PR 6450569: Crash on Right Click in Configuration Manager
PR 1823993: Offset value field disappears if more than one part is selected
PR 1834121: Unable to open X_T file in ST3
PR 1837775: Solid Edge hangs when selecting a link in pathfinder
PR 1840226: Cannot enter an offset distance of zero
PR 2164215: Unable to create spur gear as done in ST2
PR 6469288: 'Apply Configuration' dialog comes up, when applying subassembly configuration
PR 1838609: 'Center Distance Between' missing in Synchronous Pulley Designer
PR 6447436: the Select Identical Parts command not being available in ERA
===Draft===
PR 1827819: Property-text "Mass" (in draft) is empty, if drawing is opened without model
PR 1831283: Texture Symbols and Geo not imported
PR 1836610: Unable to save a single sheet to PDF to its correct size
PR 2097195: The space of the tolerance is too large
PR 6438504: Retrieve Dimensions will only work from one model at a time
PR 1830981: Parts list header text wrapping changed V20 vs. ST3
PR 1833476: Copy link / Paste special does not give correct result in ST3
PR 1836176: Draft where SE crashes in connection with 3D Device and mouse drag
PR 1836241: Parts list is not showing FOA member names
PR 1837622: Cannot open or create drawings after installing ST3 MP3
PR 6476574: sheet being renamed
PR 1840034: Performance problem updating views with PMI model views specified
PR 6439408: Bad Display in PDF
PR 6495446: Predefined Draft Text (Annotation) Alignment does not work
PR 1840906: SE aborts when updating view
PR 2166384: Leader display has changed from st2 to st3
PR 6461898: %RT does not work like it did in ST2
PR 6491943: Drawing view properties section tab not enabled/disabled based on PMI view selected
===Insight/View & Markup===
PR 6483466: Search not returning results from top level site only sub sites
PR 6484521: Crash saving as pdf into a DocLib with required properties
PR 6497333: Errors in Insight Logs since upgrading to MOSS2007/ST3
PR 6483575: FOA property mapping problems with SharePoint
===Part/Profile/Sheet Metal===
PR 1834162: Draft option in synchronous extrusion doesn’t work properly
PR 1824904: "Show only" is missing in ST3 ordered
PR 1832775: close corner reacts different in ST2
PR 1833282: Sheet metal local symmetry doesn’t work (Live Rules)
PR 6493372: Bend direction not showing on printed .psm documents from batch mode
PR 1835549: Unable to pattern a feature
PR 2164158: Extrude created a feature with a duplicate name
PR 6489351: Crash occurred while reorienting the steering wheel while in SE Simulation
PR 1838826: Dimensions placed with feature are not editable in FOP
PR 2165475: Japanese command tips being garbled in crashlogf.txt
PR 6493558: User is unable to scale a part copy when importing it into a new file
PR 1826580: It’s not possible to assign part material with ordered and synchronous features
PR 1829378: Material Thickness on Gage tab of File Properties dialog is no longer accessible
PR 1833358: feature library is not working
PR 1837948: Unable to flatten a psm file
PR 1838687: Solid Edge aborts when populating FOP members
PR 2165291: Normal Distance causes an abort in Japanese ST3 - Sync
PR 6385655: radial edits taking too long for synchronous models
PR 6389400: Wrong result on flat of conic shape with cutout
PR 6442323: cutout in ST3 synch part that takes 10-30 times as long as ordered
PR 1704478: After dissolving UDS, features don't remain selected
PR 1816608: smart pattern performance - applies to both pattern and pattern along curve
PR 1838985: Countersink is lost when re-bending
PR 2166692: Unable to select curve control points for connects with Solid Edge x64
PR 6461572: Pattern Plane creation is incorrect most of the time
PR 6469130: Product uses a lot of memory when placing sync cutout using Text Profile
PR 6509580: edit handle arrow does not point to edit face
===Solid Edge Embedded Client===
PR 6479486: SEEC API OnGetWhereUsedForAutomation does not work
PR 6495362: Unable to Check-in documents; returning document has moved or is missing error
PR 6507472: Need to verify the back port Item Number - Find No. Integration project
PR 6484387: No warning given for Item id conflicts with virtual components
PR 6512292: Next Available Number command doesn't consider TCVC
PR 6441245: Modified weldment feature is not updated in structure manager in RAC
PR 6471911: SEEC does not recognize multiple revisions during open in an assembly
PR 6482868: With PS_new_seqno_mode=none the Occurrence Properties show nothing
PR 6512110: after deleting assembly feature the JT is not updated in the Tc viewer |
