查看: 16925|回复: 8
哪位大哥知道HEIDENHAIN的用BLOCKWISE方式通讯
发表于 2003-7-31 20:59:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位大哥知道HEIDENHAIN的用BLOCKWISE方式通讯的CNC怎样DNC连机呀,在软件中怎样设置?谢了。
发表于 2003-7-31 21:41:56 | 只看该作者
用的什么DNC?
发表于 2003-7-31 23:20:00 | 只看该作者
cimco DNCMax和XperDNC楼上的大侠能否给推荐一个?
发表于 2003-8-1 21:08:16 | 只看该作者
楼上的大哥还有版主来帮帮我呀。
发表于 2003-8-1 21:26:16 | 只看该作者
Download DNC from HEIDENHAIN company web site is Free!
发表于 2003-8-1 21:40:18 | 只看该作者
谢了,能否告知具体的软件名称或者给一个地址,我的E文不行。
发表于 2003-8-1 23:08:29 | 只看该作者
Introduction:
The Heidenhain TNC controls can communicate bi-directionally using a proprietary "Blockwise" error checking communication protocol.  This protocol is used for running Direct (drip feed) DNC on long 3-D CNC programs, as well as when uploading and downloading of programs into memory.  At the CNC control, single or multiple files can be specified for upload/download as well as deletion.  FE Protocol is preferred over Heidenhain LSV2 Server Protocol, because the throughput of characters is faster.
Notes for Heidenhain FE Protocol:
1.  XpertDNC works with the Heidenhain controls in the conversational program format and the ISO (G code) format.
2.  To set parameters, hit the MOD key, and use the arrows to access each of the parameters.  Hit the MOD key again when you are done.
3.  The setting of the parameters is accomplished from the Parameter key on the control.  Menu driven functions show the various selections for Baud rate, Parity, etc.
4.  The Blockwise parameter is MP5030.0 when using EXT1, and MP5030.1 when using EXT2.  Set these parameters to 1 for Blockwise, 0 for normal ASCII communications.
5.  FE protocol is used for almost all the Heidenhain TNC controls.  EXT is only used for those few controls that don't support FE protocol.  Using EXT protocol, Remote directory is not supported.  All filenames must be entered in at the CNC control, so the CNC operator must know the required file name.
发表于 2003-8-1 23:11:13 | 只看该作者
1. Receiving programs at the Multi-DNC computer in FE mode
Multi-DNC must be in the Remote mode, as it uses the Program name on the CNC control to automatically name the files that are received at the Multi-DNC computer.  The extra error checking characters are stripped off and only the main program is saved.
2. Sending programs to the Heidenhain CNC control in FE mode
Multi-DNC must be in the Remote mode, but there is no other interaction required at the Multi-DNC computer, as all of the work is done at the CNC control.   To run a program in Direct (drip feed) DNC mode, pick that option from the control when you are copying the file from the DNC computer.  The Messages feature of Multi-DNC will not work with FE protocol, and are not needed.
**** Some of the older Heidenhain TNC controls (150 Series) do not have an FE Protocol choice, instead use EXT protocol set up with "Blockwise" error checking.  The following sections are for those earlier controls.
1. Receiving programs at the Multi-DNC computer in EXT mode
Because the program numbers must be known to load the programs back into the Heidenhain control, Multi-DNC must be in Remote mode when you are sending programs back to the DNC computer, so that they will be named consistently.
2. Sending programs to the Heidenhain CNC control in EXT mode
When you select the Read mode on the CNC, you have to type in the required file name, this information is transmitted to Multi-DNC, and it uses this to determine which file to send back to the CNC.  Multi-DNC is in Remote mode, it finds the requested file, sends it back to the CNC control.  To run a program in Direct (drip feed) DNC mode, pick that option from the control when you are copying the file from the DNC computer.  The Heidenhain file name must match the actual program name.  The Messages feature of Multi-DNC will not work with EXT protocol.
Multi-DNC = XpertDNC:I
发表于 2003-8-2 01:52:20 | 只看该作者
https://filebase.heidenhain.de/public/?open[]=64&open[]=68
GMT+8, 2025-4-26 19:59 , Processed in 0.023767 second(s), 11 queries , Gzip On, Redis On.
